how do i remove rear trunk carpet
kulluminati777
Post by kulluminati777 »
i am try to redo my interior but i cant get the darn carpet off the top of the back seat...i have pulled the clips as hard as i could and i think i broke a couple but i want to be able to put it back on....PLEASE help
ninjajim4
Re: how do i remove rear trunk carpet
Post by ninjajim4 »
there is no secret... that's how you do it. pull all them suckers out. they aren't really designed to be taken in and out. just use a flat head screwdriver and pry them up carefully, prying up all around the head, not just at one side or the other. take your time, and you should keep the breakage to a minimum. parts store will carry very similar replacements for the broken ones
Evo_Spec
Post by Evo_Spec »
buy replacement clips and just go nuts cause their probably just going to break anyways, that's pretty old plastic holding it on.
cWs306
Post by cWs306 »
what evo said. see it as a Christmas present, i did the same thing. tugged and pulled for about an hour trying to be gentle, till i flipped my lid and just ripped it off. broke 5 of them. $27 at part source if you got that store where u are.
kulluminati777
oh ok thanks alot guys i guess i will finish up tonight then
MrMazda92
Post by MrMazda92 »
If you haven't done it yet, I have a tip.
Buy the replacements at Lowe's, they're cheap and they have black, tan, white, and more colors available.
Yank the B**ch out, if you're careful you might save half the clips(if you're lucky)
ninjajim4
Post by ninjajim4 »
tsk tsk.. impatient youngins...
AaronTietje
Post by AaronTietje »
Buy a push pin puller my friend.
cWs306
Post by cWs306 »
i came to realize..if your gentle u can get it off without breaking a single clip. did it in my friends last night! all i did was pull the carpet and just made the clip's act like a button up shirt...0 clips broken. 1 a little bent. (wish i woulda had more patients when i did mine..5 clips broken) lol.
Dragon1212
Post by Dragon1212 »
you could try to get them off by using a pair of wire cutters like a clip puller, but you have to watch you don't cut them off
so in short Just buy new ones tree clips are garbage!
and you ripped the carpet not enough it matters tho
Worklog for the Blue One
Worklog for the KLZE
First Car, And My baby... $550 To buy and repair from Write-off... The radio and amp that was in it was worth more than that!!!.
Hunting For a Supra MKIV, but I'll never get one. Still Hunting.
Return to “Appearance”
