Ok its beeeeeen a long while but im back with brand new items to sell.
I have 6 k1 rods and 6 weisco pistons with toga bearing and rings included.
Full topline gasket set
iridium sparkplugs
8 mm sparkwplug wires
new brake pads
southbend clutch and light wight fly wheel plus pressure plate
new timing belt.
Here is the pics just in case i missed anything.
Message me for pricing, will go cheaper if u can do local pick up...im so lazy : P
