[FS] - k1 super beefy rods and weisco piston set plus tons
XxantwawnxX
Post by XxantwawnxX »
Ok its beeeeeen a long while but im back with brand new items to sell.
I have 6 k1 rods and 6 weisco pistons with toga bearing and rings included.
Full topline gasket set
iridium sparkplugs
8 mm sparkwplug wires
new brake pads
southbend clutch and light wight fly wheel plus pressure plate
new timing belt.
Here is the pics just in case i missed anything.
Message me for pricing, will go cheaper if u can do local pick up...im so lazy : P
Re: [FS] - k1 super beefy rods and weisco piston set plus to
No. Pricing must be posted...
and welcome back... haven't seen you around in a while!
Dali
Post by Dali »
i might be interested in everything minus the plugs/wires and pads. depending on prices.
1993 White gs klze.
WhiteFinish
Post by WhiteFinish »
What are the specs of the pistons ?
Oversized? Higher CR?
The K1's are just regular sized KL rods ?
How about the headgasket ? Is it oversized or OEM size ?
If price would be good I'm interested in the K1 + perhaps Wiseco pistons.
Just another Mx3 freak :)
Feedback topic: Click
Worklog click
XxantwawnxX
the k1 rods are wayy beefier and they are h beam. but they fit right in. fat top pistons stock klze bore. and the wires are 10.2 mm not 8..sorry.
here are the links to the pistons and rods on site
http://www.importperformanceparts.net/i ... s-all.html
second link is for pistons..you have to click ford then pistons....then weisco and the descriptions is there.
ill sell everything there for 1500. rod pistons ring and bearing combo for 1k, ill through in the gaskets.
oh and thanx mooneegs.....it has been quite sometime. Half expected the site to be down
Still waiting for you to price the items?
