Smoke Taillights/Headlights
Sisko182
Post by Sisko182 »
I am sure this has been covered before, however, when I used the search feature on the site I only found this thread... from EIGHT years ago:
http://www.mx-3.com/phpBB3/viewtopic.ph ... ht#p162496" onclick="window.open(this.href);return false;
I am sure there are better techniques since 2002. In looking at videos on how to smoke taillights and headlights, I see tinted sheets being used. I have been unable to figure out what these are called, or where to get them. If someone could let me know, that'd be great.; or even better techniques than the sheets. Thanks!
$i$Ko
Ride:
1992 Midnight Purple MX-3
Worklog:
viewtopic.php?f=46&t=75646
viewtopic.php?f=37&t=76781
Demonic1
Re: Smoke Taillights/Headlights
Post by Demonic1 »
http://www.decalfx.com/smoked_tail_light_film.html
It's the same tint film you would use to do your windows. Vinyl + a heat gun to stretch around corners.
Wings on an MX3? What are you thinking?
92 RS BP05
93 GS KLZE
(Previously owned by 2Fazed and then mrMazda92)
fowljesse
Post by fowljesse »
I use VHT NightShade. It has worked great, and you can make it as light or dark as you want.
SteeleMX3
Post by SteeleMX3 »
+1 for VHT nightshade. Stuff does exactly what it's supposed to do and probably just as well as the tint does it.
1992 Mazda MX3 Precidia GS-KLZE :: Rockin' my world since 2009
viewtopic.php?f=46&t=72989 ---> Workloooogg
johnmx3ze
Post by johnmx3ze »
-1 for niteshade! i used window tint for my mazda 3 tails!!!
you have to be sure you put the same amount of spray on both lights or else its gonna look bad!
MX3-4U2NV
Post by MX3-4U2NV »
+1 for VHT Nightshades. Used it plenty of times on plenty vehicles. Never had a problem with an unbalanced look, because I took my time.
If you make three passes on one tail light, make three passes on the second tail light... Simple really...
mikeinaus
Post by mikeinaus »
i just did mine a couple hours ago with vht nightshade. it works awesome. however i think i did my side marker lights a bit too thick cuz there not shining threw very much. ill probably just upgrade them to leds and it should be fine.
JDMChris
Post by JDMChris »
Canadian Tire
13 ish $
Return to “Appearance”
