Ok so I was trying to do some cleaning up and found another issue. There is about 20" length of wire ( 2 green ones ) that seem to have gone to the end of something at one point but have been since ripped out.
I took the best photo I could with my crummy KODAK so bear with me XD
The green wires go down into a black clip that has yellow wire locks at both sides...anyone know what these go/went to ?
Umm...2 green wires ?
- EggyRollz
94 Tahoe Sport SS - 454 =)
93 3KGT VR4 - K&N Filter.Proxes 4 Tires. Drilled/Slotted Rotors.
97 Tahoe - Grill gaurd.Oversized Tires.Custom liners.Bored & matched pistons.E-cam.Leather.Remote start.TCC upgrade.+Sunshell.10K tow package.Knifed TB.Flowtech Huggers.Straight pipes.Hypertech chip.B&M Trans Controller, Front diff & T-case plates.
Feedback-viewtopic.php?f=37&t=74259
For Sale-viewtopic.php?f=2&t=74832
- EggyRollz
Re: Umm...2 green wires ?
Don't know if it helps or not but these were hanging down under the car. Roughly around the o2 sensor. The clip also plugs into the main connector about mid-engine bay just above the transmission. This is a manual vehicle btw if it matters any.
I would like to get these back where they belong and see if some of my problems vanish.
- PATDIESEL
It is either the neutral switch or the reverse switch. Both are 3/4"ish plugs on the trans and either are subject to damage from road objects. I've replaced both on my car over the years for the same reason, ran over something and it tore the wires away.
yea that would be your neutral swtich as far as i an tell.
- Ryan
Its actually a fairly important sensor. You may notice an increase in mileage by repairing it, actually.
http://www.mx-3.com/manuals/showimg.php ... F2-018.gif" onclick="window.open(this.href);return false;
