weede`s KL-ZE Supercharger - Megasquirt
Hello, My name is Jerry and I come from Poland
Here is my 94` Mazda:
2015 SETUP
Engine:
2.5v6 KLZE engine (Full rebuild)
Oil filter relocation kit (custom)
KLZE straight-neck intake
Millenia-S injectors 280cc
Millenia-S Rods with ZE pistions (custom pins)
StandAlone Megasquirt II ECU
Eaton M62 Supercharger with custom bracket
AFR Innovate MTS with Gauge
FPR Turbosmart with custom adapter
MAP Sensor conversion
2,5" exhaust with twin-loop OBX mufler
2,5" ss headers
FMIC with custom aluminum piping
Gearbox
KL gearbox
Mazda KL LSD (torsen)
III straight cut gear PAR Engineering
ACT KL clutch kit w. 6pads
short-shifter
Brakes:
Mazda Xedos 9 brake pump with servo
Mazda 6 calipers with 283mm rotors
Goodridge steel lines
FERODO pads
Suspension
Tokico HP Struds
Ground Control Coilover Kit with Eibach springs
Eibach cambers
Poli-Brush red
Rear and front strud bars
Wheels
Dragwheels DR-23 Rally Bronze 16"
Yokohama AVS 205/50 tires
Dragwheels black screws
Interior
Sparco Torino II Seats with custom rails
323 GTR momo steering wheel
Oil temp, Oil Press, Intake pressure gauges
AFR Gauge Innovate
ALPINE CDE-101R
2015 SETUP
Engine:
2,5" ss headers
Gearbox
KL gearbox
short-shifter
Brakes:
FERODO pads
Suspension
Tokico HP Struds
Eibach cambers
Poli-Brush red
Wheels
Interior
AFR Gauge Innovate
ALPINE CDE-101R
- solo_ryder
Re: 94" weede`s JDMstyle MX-3ZE
O-M-G...
This has to be the best mx3 that I have seen for some time! Very clean and well modded. Wow
ditto - nice first post! Sweet mx-3 man, welcome to the forums!
- AaronTietje
Wow super nice and clean. Where are you located???
- solo_ryder
He's from poland by the looks of it
thank`s everyone
I`m doing a research about force induction with a Eaton m62 like this:
A plan is to have 250-270hp becouse after that it will be some problems with gearbox
I`ve done a proper list to this modyfication:
- eaton m62 supercharge (i think 0,5bar it will be enough) - what belt will fit?
- mounting kit replace Air conditionf supercharge
- millenia s rods
- millenia s 270cc injectors (will it adequate to about 250hp?)
- slim ntercooler + piping
- smt6 or MS computer
- egt, oil temp. gauge (something else? afr?)
- walbro 255 fuel pomp
Maybe it will be my winter project if everting goes right
- millenia s rods
- solo_ryder
You will need to take a peice of string or tape and make a loop and get the measurement that way and get a custom belt.weede_klze wrote: - eaton m62 supercharge (i think 0,5bar it will be enough) - what belt will fit?
You dont need rods, the stock rods will hold as long as you have a good tune, that way you dont need to take apart your motor. Milly s injectors will work fine.weede_klze wrote: - millenia s rods
Boost, AFR and EGT or oil press are most important.weede_klze wrote: - egt, oil temp. gauge (something else? afr?)
Thank`s! I`ll still doing some research about this.
KLZE + supercharge sounds insane!
http://www.youtube.com/watch?v=5PTrZJvA ... re=related" onclick="window.open(this.href);return false;
- TrevorTheGallant
Dude! Wow! So nice! 5*
- diezzel
Thats one sharp looking MX3.Love it in white.Keep it clean and stock looking.
I don`t like spoilers at all only exception is mazdaspeed front bumper which is very very rare in europe and corcsport with shipping too expensive
- AaronTietje
This may be a long shot but I would be willing to look into shipping you a mazdaspeed for an oem like you have on your car (with a lip). Just a thought.
- RS_OBD'oh_2
Does that sticker say SRT8????
- Evo_Spec
i was wondering when someone would mention thatRS_OBD'oh_2 wrote:Does that sticker say SRT8????
