Looking To turbo my DOHC 1.8
HardShifter
Post by HardShifter »
I'm plaining on installing a T3/T4 Turbo Charger on to my 1.8 DOHC MX3. Can my engine handle that the way it is or should I upgrade anything in the engine like the valves and cams. if so where can i get these parts? I'm also having a hard time finding a turbo manifold and downpipe.
ice_mann
Re: Looking To turbo my DOHC 1.8
Post by ice_mann »
You should check the FAQ's and use the search function, theres countless posts on the subject... :roll:
95 MX3 GSZE- Silver, TWM STS, suspension techniques lowering springs, moroe struts, bronze-oil shifter bushings, leather MS shift knob, strut bars(Fleabay), ss headers, spec stage 3 clutch, fidanza flywheel , outlaw spacers, MS motor mounts , custom ss door sills, spyder projectors
WTB
coilovers
Megasquirt(dont know which one yet)
Slim Fans
RS_OBD'oh_2
Post by RS_OBD'oh_2 »
if you've upgraded to the 1.8BP, (from the 1.6b6) read mike's worklog. T3/t4 may not be your best choice, start with the manifold then go from there.
HardShifter
I haven't been having much luck finding that information on here. That is why I am asking. There is stuff about turbos but nothing about what I wanna know.
Demonic1
Post by Demonic1 »
The BP is a pretty stout engine, even with stock internals. It should be able to handle 7-8 pounds of boost without any issues. T3/T4 would probably be overkill though.
Upgraded internals are needed/recommended for any real power.
The manifold will more than likely have to be custom made. There may be some in the for sale section.
http://www.mx-3.com/phpBB3/viewtopic.ph ... urbo+boost" onclick="window.open(this.href);return false;
Wings on an MX3? What are you thinking?
92 RS BP05
93 GS KLZE
(Previously owned by 2Fazed and then mrMazda92)
RS_OBD'oh_2
edt racing makes the bp turbo mani. I believe it bolts to a gt25/28 frame. What clutch are you running in the bp? If you have not upgraded it, you should do so first. Stock b6/bp are good for 200-250 in stock form... IFFFFFF it has a good tune.
HardShifter
The only thing that is done to the tranny is the Clutch. it came with it so I'm not sure what kind but its not stock. It grips like a racing clutch.
Limegreen mx-3
Post by Limegreen mx-3 »
T3/t4 is not over kill given to do a decent turbo setup, engine management is the key. If your not wiling to do neither, because it isn't cheap than yes wanting to install a t3/t4 turbo is over kill.
What are your power goals if your thinking spending 500 bucks will get you in turbo form, your better off all motor.
HardShifter
I have been looking around for valve and cam upgrades. anyone know where I can Possibly find those online?
mrwhite
Post by mrwhite »
I find RS oh to be very helpful
To answer hardshitters question, supertect makes parts for the engine. Belfab products. Eagle I believe. There's one more company that I kno of I think wiseco (sp)
