Built KLDE or go KLZE?
illinin09
Post by illinin09 »
I currently have a 93 mx6..i know i know, this is mx3.com but whatever. I am looking into doing an engine rebuild. PAECO has some good prices on redoing my cams... INTAKE: 34/66 EXHAUST: 70/30 DURATION: 280 LIFT: .302"...and im looking at
this for the engine.
Bore Includes:84.5mm
Complete Gasket Set
Hussey Copper Gasket
ROSS/Wiseco Forged Pistons
(86, 85, 85.5mm bore) and
(9.1-1, 10.1-1 comp ratio)
Upgrade to JE Pistons (Add $109 to kit price)
ROSS Performance Rings
Performance Wrist Pins
TOGA HP Main Bearings
TOGA HP Rod Bearings
Thrust Washers
Timing Belt
Additional Parts Available:
Pauter Connecting Rods
K1 Rods
I would be doing all this on my KLDE, or would you guys suggest throwing in the KLZE and working on that instead?
fowljesse
Re: Built KLDE or go KLZE?
Post by fowljesse »
I would recommend doing the DE with a KLG4 IM, with port & polishing, deshrouding, and reconditioned or new HLAs. That's what my build basically is, and it's the strogest KL around, including ZEs. If you don't want to do the machining, I'd recommend the ZE, and a chipped ECU, or EMS.
illinin09
Post by illinin09 »
dont mind taking it to a machine shop at all haha...but isnt the G4 an OBD2? im 93, so OBD1... and you think the g4 mani is better perfomance wise than the Ze IM?
fowljesse
Post by fowljesse »
It doesn't matter that the G4 is newer. The sensors all hook up, and the VRIS points are closer to the stock ones than ZE ones.
Check out xtremethingsdotcom. It'll explain better than I can about the G4, and whatnot.
Definitely do a worklog!
illinin09
Post by illinin09 »
so just go with the G4 IM and leave the stock pistons?
solo_ryder
Post by solo_ryder »
Get a ZE and spend that kinda coin on something else
illinin09
Post by illinin09 »
"something else" meaning...? haha not very helpful
fowljesse
Post by fowljesse »
If you're rebuilding, Higher compression is the #1 way to gain HP, and cams is #2. The DE heads actually flow pretty well, but I'd deshroud, port/ polish... do everything you can while it's apart, even if it uses up your budget, because you can do the other stuff more easily. You can build a DE to be stronger than you can a ZE, because the DE has more material to remove...
It all depends on your goals, time, and budget. If I had an unlimited budget, I'd build a DE, just because you can make the flow better.
Just copy my build, but do it with actual car parts :wink:
BUt seriously, I'm curious what your budget is, and what your goals are, because there's always ITBs, coilover plug, forced induction, engine management, etc..
illinin09
Post by illinin09 »
Honestly goals are to have a strong/reliable dd...that will haul. I can afford a few days of not driving it but im not gunna go w a turbo cuz u never know when that will poop out on you. I dont have a buncha money saved up, I get my paycheck and i buy things. So i guess my budget would be like 500 a month or so. heres what im planning right now. Borla Cat-back with a magnaflow high-flow cat, and a resonator. The KLG4 IM, cept i have not seen a build thread on that and have no idea the time/pain of doing that so if you wanted to let me know how many hours that took? After i get that ill prolly bore out my DE TB, unless i should get anotther one with the G4, not sure on that. ANd then move on to save up and get about 1500 Set aside, so i can get milli s rods and pistons, 11:1 comp, and find a good machine shop to help out with that. THoughts?
solo_ryder
illinin09 wrote:"something else" meaning...? haha not very helpful
It's plenty helpful. Use your head. If all you want to do is "haul a--" then I don't see how that expensive rebuild kit is gonna help you. Get a ze with bolt ons or run nitrous or something.
illinin09
Post by illinin09 »
if you read the post, i wanted a strong/reliable daily driver. Nitrous doesnt really seem like that to me.
solo_ryder
illinin09 wrote:if you read the post, i wanted a strong/reliable daily driver. Nitrous doesnt really seem like that to me.
Strong and reliable and fast aren't usually in the same sentance. Building a de or ze to 11:1 comp is sketchy. Sure your motor will be freshly rebuilt, but can you find a shop that knows how to work on kseries v6's? Are you comfortable with the fact that if your timing belt fails that your motor takes a crap with the belt because you lose the "non interference" aspect of the motor due to the piston design?
Nitrous and kl's go very well together. There are guys on PT that are running nitrous for YEARS with no issues at all, while all the turbo and built motor guys are either blowing up their motors or parting out their builds because they became too expensive (in many cases worth more then the car they are driving).
I'm not trying to s--- on your plans but you have to be realistic and be careful on how you spend your cash because it can be gone so fast on these motors/cars you will be left broke wondering wtf happened and having to end up parting your loses...
fowljesse
Post by fowljesse »
xtremethingsdotcom has all the info about the G4 IM (and other good DE build info), and I did see a little gain with a 65mm TB. Port/ polishing, etc. time varies depending on how good you are at it, how far you go (the closer you get to doing too much, the more careful and meticulous you need to be), and how good a final job you want. A quick P&P/ deshroud job will take a full day, if you've done it before, and are good at it/ know your tolerences.
I would also stay at 10:1 compression, and get Colt 210 cams, for max performance, while still being streetable. My car is just at the edge of streetability. It doesn't go smoothly from stopped, It wants to jerk, so rush traffic sucks.
Post by wytbishop »
solo_ryder wrote:
illinin09 wrote: ...you have to be realistic and be careful on how you spend your cash because it can be gone so fast on these motors/cars you will be left broke wondering wtf happened and having to end up parting your loses...
Quoted for truth! I have seen so many builds die for lack of funds I can't even count.
illinin09
Post by illinin09 »
I get that nitrous might not be bad but the resason for an N/A build is to have power all the time not just when i open up the spray.
If i go ahead with some ZE Pistons and Colt 210 Cams with a full exhasut and a G4 IM, why does that seem so ridiculous price wise?
