coolant hose routing
ok so im pretty much ready to put my ze in but im stuck on a few lines. i cant find them on the online manual or the computer at work, but i have the millenia IM and im stuck on where the tb and iac lines went to. stupid i know but yea. and yes i searched. could someone just throw up a few pics if they dont mind
Re: coolant hose routing
wow nice to see how helpful people are
- Tollis
Just look for them get under if you have to. Use your head on this one
Cody
1993 GSZE SE
1993 GSZE SE
Can you look at your K8, most things are very similar. I think your post just got over looked.
i dont have a k8 and i have nothing to look at and i have to make the lines for it. thats why im asking for someone to take a few pics or osmething
- Newfie_dan
if you dont have the v6 then you have posted this under the wrong section friend, get a haynes manual or search the online manuals they have all the info you need.
I had this same issue last year when I took both of my TB's off both of my ZE's at the same time and I forgot which way the coolant lines were supposed to go... I believe this is what you need:
http://www.mx-3.com/manuals/showimg.php ... B2-034.gif" onclick="window.open(this.href);return false;
how in the world did you find that, i went through that entire manual and the entire computer at work adn couldnt find a single thing. man thanks a bunchMooneggs wrote:I had this same issue last year when I took both of my TB's off both of my ZE's at the same time and I forgot which way the coolant lines were supposed to go... I believe this is what you need:
