I have a 1992 Mazda MX-3 GS 5-SPEED with a 2.5ltr v-6 motor. 3,500.00 neg.
ALL NEW PARTS ARE AS FOLLOWS: NEW CLUTCH, LIGHTWEIGHT FLYWHEEL, LIGHTWEIGHT CRANK PULLEY, WATER PUMP, PWR STEERING PUMP,
ANGEL EYED PROJECTOR HEADLIGHTS, SMOKED TAILLIGHTS, SHORT SHIFTER, JDM STEERING WHEEL WITH SHORT HUB ADAPTOR,
NEW CUSTOM MAGNAFLOW DUAL EXIT EXHAUST SYSTEM FULL 3" FROM THE HEADERS, DIAMOND AUDIO COMPONENT SPEAKERS IN THE
FRONT AND REAR, CROSSFIRE AMP, NEW BATTERY, DIGITAL BATTERY TERMINALS, THERMOSTAT, DRIVE BELTS, PWR WINDOWS,
PWR DOOR LOCKS, 2 OTHER INTAKE MANIFOLDS ONE DRILLED AND TAPPED FOR DIRECT PORT NITROUS. NITROUS KIT AVAIL AS WELL.
HAS CARBON FIBER DASH BEZEL, REVERSE GLOW DASH LIGHTS NOT YET INSTALLED, ALONG WITH PUSH BUTTON START AS WELL NOT YET
INSTALLED. NEW REAR BUMPER AND ALSO HAVE SIDESKIRTS TO GO WITH AS WELL. CAR RUNS GOOD AND SOUNDS MEAN.
I HAVE TONS OF EXTRA PARTS AND STUFF LAYING AROUND FOR THIS CAR ALL WILL GO WITH IT IF YOU WANT IT
FS : CT - 1992 WHITE GS WITH 2.5ltr
1992 MAZDA MX-3 GSR 2.5LTR V-6
2005 SUBARU STI
2004 NISSAN ARMADA
http://www.cardomain.com/id/wkdmx3gsr
http://www.netuners.com
2005 SUBARU STI
2004 NISSAN ARMADA
Re: FS : CT - 1992 WHITE GS WITH 2.5ltr
2005 SUBARU STI
2004 NISSAN ARMADA
2005 SUBARU STI
2004 NISSAN ARMADA
- onlytrueromeo
That's a K8 Intake Manifold, so either you're lying or you're not taking advantage of the 2.5L by restricting its power.
- mx3autozam
Going by the messy plug wires and the labled vacumn lines in the pic the motor has probably been pulled. Alot of people run the k8 manifold for the ease of installation.
93 Mazda MX3 KLZE Turbo
- mx3autozam
onlytrueromeo wrote:That's a K8 Intake Manifold, so either you're lying or you're not taking advantage of the 2.5L by restricting its power.
wow people are quick to call other LIARS on here... Its been swapped to a 2.5 probe moter as stated. No crap it is a 1.8ltr manifold i have the MS8 manifold as well as the straight necked probe one too. all manifolds go with the car along with all other parts in my 3rd garage.
2005 SUBARU STI
2004 NISSAN ARMADA
2005 SUBARU STI
2004 NISSAN ARMADA
mx3autozam wrote:Going by the messy plug wires and the labled vacumn lines in the pic the motor has probably been pulled. Alot of people run the k8 manifold for the ease of installation.
Thanks and its the wifes new 2008 EVO X GSR.
2005 SUBARU STI
2004 NISSAN ARMADA
2005 SUBARU STI
2004 NISSAN ARMADA
