Same thing here too on the KLZE car - almost - just a creak not a clunk....and I think I diagnosed it even though I don't like it.
Here's the facts:
1) Slight creak under braking
2) Diagnosed slight run out on brakes
3) Run out is transmitted to knuckle even though it appears that the caliper is ok
4) Knuckle is transmitting runout through strut
OK - here's the possible NON fact:
The strut seems to be taking the motion and the strut internals are moving ever so slightly relative to the externals causing the creaking sound...
Solution - get rid of the run out!! OK and check my struts too....
Clunking when braking...
Re: Clunking when braking...
1993 GS SE - "slow" (Stock) - SOLD
1993 GS SE - "fast" (Curved neck KLZE, OBX headers, custom 2.5" exhaust, KL36 ECU, Exedy Probe GT clutch, KL36 LSD - the real one, Lantis Type R lefthand halfshaft - unfortunately worth mentioning)- SOLD
1993 GS SE - acquired 4/28/2013, SOLD February 28, 2015
1985 RX-7 GSL-SE - SOLD
2003 VW GTI 1.8T
2009 Mazda5 Grand Touring
2003 VW GTI 1.8T
- ooELMOoo
My problem started off going over speed bumps I would here a creaking noise. Then as time went by when I went around corners, it started creaking. It got to the point that anytime the suspension moved, it sounded like my wheel was going to fall off and people were getting scared on the side walks when I would drive by them. It ended up being the bushing on my control arms. I unbloted the one bolt. Lithiumed the hell out of the bolt and all contacting metal points on the contol arm. After that it was so quiet I could here that my rear calipar is sized and has chewed away at my rotor
| CUSTOM X3|
| CUSTOM X3|
about this problem, today im going to ask my mechanic if this will work the trouble :OutlaW wrote:ok, i definetly have this problem in my car. I stop at a section, wait for cars to open a space, and go. When i turn the steering wheel , it sounds as if my wheel as a broken stuff in it.
I am constantly replacing CV joint boots, is the MX3 prone to rip those ?
Well, for now replacing it will not do the trick, i must have a CV joint dead ... what do i need to look, to get it fixed ? i guess both front one's are dead or diying ...
a CV Joint Outer Kit ... picture as follows
its really annoying going somewhere, and having a nice car that has clunking sounds, its NOT COOL
K8 :: 136.8 bhp---160 nm---108.0 whp---118lbs/torque
ET: 15.567 @ 136 kmh (84 mph)
"Racing a Honda is like being in the special Olympics, you may win, but in the end your still retarded."
