mx-3_4evr 94 RS
How much WHP will I have after my turbo build?
250WHP
1
17%
260WHP
0
No votes
270WHP
1
17%
280WHP
2
33%
290WHP
1
17%
300WHP
0
No votes
300WHP+
1
17%
Total votes: 6
mx-3_4evr
Re: mx-3_4evr 94 RS
Post by mx-3_4evr »
^ It's actually flat shift / launch control. I'm going turbo, look at my post from August 18th :)
Limegreen mx-3
Re: mx-3_4evr 94 RS
Post by Limegreen mx-3 »
they have so many names for it ms calls it that tec calls it this etc etc..
460cc seem small but if ur for under 300whp than ur ok..
mx-3_4evr
Re: mx-3_4evr 94 RS
Post by mx-3_4evr »
I ordered 550cc injectors but the dumn a-- sent me 460cc injectors instead. He said that the 195500-2010 were 550ccs. Anyways he sent me half of my money since he messed up. :D
Limegreen mx-3
Re: mx-3_4evr 94 RS
550cc would be better just make sure u don't go over 90% duty cycle on ur 460cc..
-Custom made intake manifold with a Ford TB 68mm sounds like a good investment. send a pm on some of the stuff u pick out. U are going to run with a N/A BP block..
mx-3_4evr
Re: mx-3_4evr 94 RS
Post by mx-3_4evr »
Here is a pic of the turbo manifold. It's a miata one, cut, flipped, then welded back on. It used to be smoke187 (I think that's his screen name here on mx-3.com and clubprotege) I think it will work just fine. Someone welded a plate so it wouldn't crack due to stress. Anyways, onto the pics :D
Before:
After:
I used VHT ceramic paint. I baked it for 30min and then let it cool to room temperature. The turbo flange needs a little bit of work since it's not completely flat. I might have my buddy deck it or just weld a new T3 flange. Also the wastegate flange will be cut and be replace with a 90* elbow to be able to clear the radiator. (the wastegate will be facing the pass side headlight)
mx-3_4evr
Re: mx-3_4evr 94 RS
Post by mx-3_4evr »
New thread here: viewtopic.php?f=46&t=71605" onclick="window.open(this.href);return false;
