So I picked up my very first mx 3 two days ago.
A 94 GS, now after putting it on a hoist I noticed my front right spring is broken.
So I would like to Redo all struts and springs.
but I'm unsure of what to go with, I had read you should upgrade if you wanted to go with the KLZE, is this true? if so could someone point me in the right direction?
as well I made a unsuccessful trip to the autowreckers for a temporary fix for the spring problem (The wrench busted off before the nut turned) but I noticed it had some awesome looking seats in it. the car was a 93 RS I would assume? the seats were different than my GS seats in the way the headrest was, it was all conected with a hole in the middle rather than the single metal bracket.
I was curious if these would fit in my GS.
In no means do I have any idea what I'm talking about =)
so please forgive me for any mistakes.
Thanks.
Kyle
Need some advice on; Struts, springs, and seats =)
Re: Need some advice on; Struts, springs, and seats =)
Another Albertan!! I prefer the 92-93 seats anyway, I would get them if I were you. The broken spring is not uncommon. A nice set of lowering springs and decent struts will cost you about 600. Do a search on the online manuals and you'll have all the info you need.
1993 Blaze Red SE, 17" blackie's, b+m sts, 45 deg 3" exh pipe/intake tube, K8ZE, aftmkt probe headers, magnaflow hi-cat, all 2.5" piping, magnaflow muffler.
1976 Datsun 620 p/u, full airride, Firestone 2600`s, 16ga fuel cell, Optima yellow top, AZ compressor, custom tubular frame with 9in step notch, 18" 100 spokes
1955 Willys Overland 4x4 P/U, '78 LT1 350 cu.in, fully restored.
- Hoodzy
Since you live in Edmonton I would NOT recommend the H & R Springs. I have Eibachs and even them are pretty rough on Edmonton roads. I have KYB Gr2 Struts and Eibachs. Been up in Edmonton and all over alberta with them for about 2 years now and haven't had any problems. Make sure to replace your mounts while you are at it. Also I would say put the 93 style seats in they are a direct fit. Much more comfy!
1995 Creek Mica Blue GS
Twizz
Opps i guess I posted this in the wrong place.
When I posted I was only thinking about seats...
But I have to wait 2 days to get the seats on my day off
Hopfully there still there.
- Evo_Spec
any pictures of your car? i might have seen you tonight =P
Hoodzy is right. Due to the horrendous quality of Edmonton's city streets you'll probably be most happy with Eibach springs...or even stock springs on a nice upgraded shock. I have Eibach Escort ZX2 springs on Tokico ZX2 shocks and it's not bad...but definitely harsher than stock.
Twizz
I'v got pictures =)
Sorry about the delay,
my laptop died and someone backed into my car!
And where they hit me!
Was that on kijiji?
