And what car would that be that you could swap over the hub assembly and the rotors?Yoda wrote: It's been done more that once. At least a dozen or so times since 2003 that I know of on both MX-3 and 323s. Actually it's a pretty straight forward bolt on swap. Fortunately the MX-3 shares the same wheel bearings and spindle dimensions with a car with 5 lug hubs and same size rotors. It only requires swapping out the hub assy and rotors in the back and pressing out the front hubs out of the bearings then pressing the the 5 lug spindle back in and installing the matching rotor. When doing the front the bearing will probably blow apart so it will be best to have new bearing and seals on hand to do the job.
Project.. I take back what I said about the 5 lug swap. It would be pretty cool, even though it would be somewhat hard to find a set of FWD rims that are nice.. However, I see my bro rollin on FD's with his probe and I want a set for my mx3 so bad.. I am not sure they would fit though.. We had to use 11mm spacers in the back of his probe to get em flush with the fenders.. It would be a close fit, maybe have to roll the fenders as running 225's would be ideal on that 8" rim
![Image](http://i30.photobucket.com/albums/c302/solo_ryder/P1100369.jpg)
