Timing The Distributor
hey everyone i wanna time my distributor, i got the timing gun does neone know the specs for the ZE ? thanks
Re: Timing The Distributor
10º BTDC
I can't remember where I read it...but I'm sure I did.
Yea it's 10, make sure the engine's at operating temp. and that you're in diagnostic mode too.
KLZE-ed '94 RS/'92 GS hybrid -- It's complicated
-- Now somebody's winter beater
1999 Audi A4 2.8Q -- New ride
k kool thanks
Good luck, you can move that disty all you want and the ECU will just correct it to 10 degs. I've noticed all the cars I've checked just have the disty positioned in the middle so that's where I positioned mine. Any yes I did have TEN and Grd jumped.
I've heard that too, but if I have my TEN and GND jumped I can notice a change in the idle speed and quality if I move the disty around, so I don't know what to think.
I think that moving the disty in diagnostic mode changes the physical ignition timing, because the ECU can only compensate so much, it still depends on where the rotor is positioned at that exact moment.
- OROutdoors
???? how does the ECU adjust the timing of the ignition? Last I looked, (my) '92 GS has a coil, distributor, and rotor, but I don't see an electronic ignition.Daninski wrote:Good luck, you can move that disty all you want and the ECU will just correct it to 10 degs. I've noticed all the cars I've checked just have the disty positioned in the middle so that's where I positioned mine. Any yes I did have TEN and Grd jumped.
Oregon Outdoors
92 mx-3 GS lowered, CF hood
2013 Mazdaspeed3
2013 Mazdaspeed3
Well it must, because if TEN and GND are not jumped, you can rotate that disty all you want and nothing happens.OROutdoors wrote:???? how does the ECU adjust the timing of the ignition? Last I looked, (my) '92 GS has a coil, distributor, and rotor, but I don't see an electronic ignition.Daninski wrote:Good luck, you can move that disty all you want and the ECU will just correct it to 10 degs. I've noticed all the cars I've checked just have the disty positioned in the middle so that's where I positioned mine. Any yes I did have TEN and Grd jumped.
Jumping them enables you to change the timing. It's always good to have it in the right spot and timed well.
1995 Eunos 30x KLZE
i know dan and i have discussed this before but keep in mind he has OBDII. i've found my timing was way off before and adjusted it with timing light on a kl31
Stupid question but I never have changed the timing on my car except for the belt or the TPS.
Anyway, I have a timing light and everything.
Just dont know how to do it step by step.
Anyone have a link to a quick guide?
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
Put a paper click between TEN and GND on the diag box.
Hook up your timing light. Loosen the disty just a little so you can turn it. Turn the car on, warm up to operating temp. Look at where the timing is at. Rotate the disty until you hit 10 degrees BTDC. It's marked on the timing cover. You may need to move the coolant pipes out the way to see it.
1995 Eunos 30x KLZE
...tighten the disty. Then turn the car off. Then pull the paperclip.
And just in case you don't know, there's a little mark on the lip of the crank pulley. I think it's yellow. That's what you want to use as your reference, when you aim the timing gun at the timing marks on the cover.
Whisper wrote:And just in case you don't know, there's a little mark on the lip of the crank pulley. I think it's yellow. That's what you want to use as your reference, when you aim the timing gun at the timing marks on the cover.
+ sometimes the paint is gone. you can just use white out to re apply on the little grooveWhisper wrote:And just in case you don't know, there's a little mark on the lip of the crank pulley. I think it's yellow. That's what you want to use as your reference, when you aim the timing gun at the timing marks on the cover.
what is this ten and grd everyone is talking about?
