Ok I have a rather nice MX6 but I am thinking about moving to an MX3 as its my daily driver and well... I have always liked the MX3.
What I want to know is what can I transfer over, the tranny and motor obviously. But I am more concerned about the VR4 Brake Kit, Sway Bars, Endlinks, Millenia ECU or MegaSquirt (Which should also not be a problem), suspension and so on.
I have included everything I currently have (I just copied and pasted from my MX6.com VB Garage). What kind of advice can you give me here on this?
Performance:
KLZE J-Spec Motorswap (10:1 Compression, Bigger Intake HLA's, Rated 197HP Stock)
Custom Grind Cams by Mike Seli;
0.362" lift, 214deg @ 0.050", 264deg (adv.) for the intake cams
0.353" lift, 209deg @ 0.050", 262deg (adv.) for the exhaust cams
--Stock were 198/198 (I/E)--
Aluminum Lightweight Underdrive Pulley
CZT Intake Manifold
CZT 67MM Throttle Body
VAF to MAF Conversion w/Millenia ECU
K&N Cold Air Intake
Magnacore Plug Wires
Short Tube Headers
Test Pipe w/Wideband & Dump
MagnaFlow 2.5 Stainless Steel Catback
Webber 255 Fuel Pump
King6 Manual Timing Belt Tensioner
Adjustable FPR Set @ 40 PSI
Various Weight Reductions to include, shielding, brackets, & anything else I could get my hands on to remove
Suspension:
Mistubishi 3000GT VR4 Custom Big Brake Kit up front w/ Drilled and slotted stopped by 4 piston calipers.
Drilled and Slotted Rear Rotors
Tokiko Illuminas Adjustable Struts
Eibach Coil Overs
Front & Rear Adjustable End Links
19mm Rear Sway Bar
King6 Custom Fab Front Strut Bar
King6 Traction Bars
Rear Strut Tower Bar
Stainless Steel Clutch Line
Stainless Steel Brake Lines (All Around)
Drivetrain:
Swap to Manual Tranny Correctly
Stage 2 Clutch
MX-3 Lightweight Flywheel
Double Bend Short Throw Shifter
CZT Tranny Saver Brace
Solid Front & Rear Motor Mounts from Nolan Spawn
King6 Custom Fab Passenger Side Motor Mount
Capsule Racing Custom Made Bottom Tranny to Crossmember Mount
Exterior:
Mustang GT 17" Rims with 245's Painted Custom Light Bronze
Fiberglass Scoote Hood
Rare Mazda Rear Lip Spoiler
Painted GM Dark Black Cherry
Millenia 1 Piece Headlights
Blacked out the rear tails w/Night Shade
Acura Integra Front Lip
Interior:
Full Custom Suede Leather Interior & Headliner
Full Window Tint
Stainless Steel Door Guards (M-Edition Only Feature)
Full Interior Swap to Black
MX-3 92 Steering Wheel w/no airbag
F-Body Rear View Mirror (I wanted Map Lights lol)
Electronics:
Pioneer Deck, Pioneer Door, Pioneer Rear, Kenwood Amp
Silver Bomez Gauges
Battery Relocation to the Rear
Optima Redtop
Custom Engine Bay & Rear Trunk Grounding Kit
Thanks everyone.
I am thinking of Moving from my MX6 to an MX3 GS. Swap?
- onlytrueromeo
Re: I am thinking of Moving from my MX6 to an MX3 GS. Swap?
Mx6 - 5 Bolt hub
Mx3 - 4 bolt hub
There is a way to convert between the two, but you may have to do some fabbing!
Swaybars - NO! As far as I'm aware!
All the interior stuff will probably be different, and I know the bodykit stuff is. You can pull the drivetrain and the megasquirt, everything else will be custom work!
Mx3 - 4 bolt hub
That was the first thing I noticed obviously. I was not sure if anyone had tried to do a 5 lug conversion. 4 lugs is fine by me but the VR4 swap may be easier if I go to 5 lug.
Granted I have never seen the hub and brake mounting setup for the MX3 so I am not sure I can modify it as easily to fit an MX3.
- onlytrueromeo
There are people who have done the conversion, but few and far between, as it doesn't do much for us besides allow different wheels.
Most people who do the conversion get new holes drilled in the hubs, but I believe you can swap hubs and some other pieces to make it work - if we can use mx6 struts w/ some modification, then the hubs should be close.
Information is here or on clubprotege somewhere, you will have to search!
I have been, but felt I would talk to those here and see what information I could gather.
My suggestion is swap it into MX3 GS, because the style and the max speed rate of that car are more up. And contain the element what we call CUSTOM steel plate.
____________________
blanchard grinding
blanchard grinding
