[FS] SRD Reproduction Parts - Crossmember, Tie Bar & E-Brake
- tehbrookzorz
Re: [GI] Aluminum Crossmember & Rear Tie Bar - SRD Reproduction
Why is this the first time I've heard of this!? (Neon strut tower bar)
Cody
No word yet. I talked to Deimos last weekend and he said he need to look into what it's worth before it sells it to me...mitmaks wrote:what about SRD ebrake handle?
^^^ havent you been trying to get that from him for awhile now?
Yes I have...
Here are the pics requested for the Neon strut bar that will clear the ZE we tested on Havoc's car. Keep in mind mines just the K8 and there is plenty room! BUT you have to raise the braces by butting the brace ontop or the nuts then adding 4 more nuts.... This does not make the bar less useful!
- projectB10
the factory JDM front strut bar is mounted/fixed in exactly the same way.... dont see that as a problemBUT you have to raise the braces by butting the brace ontop or the nuts then adding 4 more nuts.... This does not make the bar less useful!
If this is still active I'd definitely be interested in both the front transverse crossmember and the rear tiebar.
- Gord
1996 MX-3 GS-ZE 2.5L 5spd
KLZE+LSD / Headers / KL02 VAF / Clutchmasters stage-I / Fidanza 9lb flywheel / Eibach Pro Kit / Tokico HPs / Urethane bushings & mounts / SSR Comp-C 16x7 / General Exclaim UHP 205/45R16 / Wilwood 13" brakes / Whiteline rear swaybar / Carputer / Software Crossover / Infinity components+subs / 41hz Tripath Amp9 / Trunk SLA batt / Keyless entry
ya man, this is just getting started
i do have 2 tie bars ready at the moment for those who are wanting one
interesting , Looks almost the same for my zx2? if so i bet some of the guys on teamzx2.com would want these
Has the price been finalized yet?
92 Mazda MX3 GS
http://www.cardomain.com/id/ukrman" onclick="window.open(this.href);return false; - cardomain page
viewtopic.php?f=46&t=66481 - worklog
viewtopic.php?f=37&t=72099 - feedback
viewtopic.php?f=2&t=71757 - stuff for sale
http://s2.metaldamage.com/c.php?uid=159229" onclick="window.open(this.href);return false; - biggest waste of time
I believe it was $200 for the front crossmember and $100 for the rear tie bar
thats correct
and flyer, you got a sweet aviater lol
- fowljesse
That Neon strut bar looks exactly like my Aerospeed, but cheaper. I bought mine from a guy who had it on his Zx2. It seems to have the same clearance as any other, which can be put up on extra nuts.
I think people with cuved neck manifolds would really like a solid brace, like the OEM, but would fit under the strut nuts.
I was able to pull up some info and that SRD was planning on selling a kit with bolts and blind fasteners for the 4cyl guys. I'm not sure if it's possible, but Jesse, would it be possible to do a quick test-fit on a 4cyl, possibly Jared's Mx, and see if it's possible to figure something out. Jeff said the holes didn't line up when he went to test fit them on on his, but I don't have anyone to verify that.
Just a note that the 2 prototypes have been sent to Jesse on the 20th, and the last tracking update that it arrived into the "destination country" on the 22nd.
