Trans question
spidy53red
Trans question
Post by spidy53red »
does anyone know what clutch i can use in the F-series tranny fit im turbocharging??
Ryan
Re: Trans question
Post by Ryan »
Any of the usual brands. Look through the FAQ's and they'll tell you what splines/diameters/sizes you can use on what trannies. I'm not nice enough to do that for you.
Oh, and your F series will explode on your driveway at the mere sight of a turbo.
nos92mx3
Re: Trans question
Post by nos92mx3 »
Ryan wrote:Any of the usual brands. Look through the FAQ's and they'll tell you what splines/diameters/sizes you can use on what trannies. I'm not nice enough to do that for you.
False, mines holding up just fine. It all depends on how you drive it, obviously any major drive line shock will kill the tranny, but if you preload off the line, keep wheel hop to a minimum and dont always power shift. It should hold up to Some abuse.
92' Rs-t b6t/De - RIP
93' Rs-t BPT - Sold
03' WRB wrx Wagon - Current
spidy53red
Re: Trans question
Kool thanks
spidy53red
Re: Trans question
Ok what about the 1.8 dohc BP from a 91 escort. is it a DBN or do i need alot to swap this motor? I found one w/ trans and ecu.
Limegreen mx-3
Re: Trans question
Post by Limegreen mx-3 »
sounds like ur an automatic
Ryan
Re: Trans question
Post by Ryan »
for a BP swap... from a SOHC, all I believe you need is the motor and ECU. run wires for VICS, and one to disty... this is all in the faq, why am I telling you.
