Trans question
- spidy53red
Trans question
does anyone know what clutch i can use in the F-series tranny fit im turbocharging??
- Ryan
Re: Trans question
Any of the usual brands. Look through the FAQ's and they'll tell you what splines/diameters/sizes you can use on what trannies. I'm not nice enough to do that for you.
Oh, and your F series will explode on your driveway at the mere sight of a turbo.
Re: Trans question
False, mines holding up just fine. It all depends on how you drive it, obviously any major drive line shock will kill the tranny, but if you preload off the line, keep wheel hop to a minimum and dont always power shift. It should hold up to Some abuse.Ryan wrote:Any of the usual brands. Look through the FAQ's and they'll tell you what splines/diameters/sizes you can use on what trannies. I'm not nice enough to do that for you.
92' Rs-t b6t/De - RIP
93' Rs-t BPT - Sold
03' WRB wrx Wagon - Current
93' Rs-t BPT - Sold
- spidy53red
Re: Trans question
Kool thanks
- spidy53red
Re: Trans question
Ok what about the 1.8 dohc BP from a 91 escort. is it a DBN or do i need alot to swap this motor? I found one w/ trans and ecu.
- Limegreen mx-3
Re: Trans question
sounds like ur an automatic
- Ryan
Re: Trans question
for a BP swap... from a SOHC, all I believe you need is the motor and ECU. run wires for VICS, and one to disty... this is all in the faq, why am I telling you.
