Shades wrote:So where in the engine bay are you gonna mount this two stroke engine?... on the hood, new hood ornament?
What RPM is the two stroke gonna be turning at to provide you with enough air flow?... will it even turn fast enough?
You're adding more weight to the car and using up more fuel... interesting.
Every 100 lbs is a tenth of a second. Big deal, a 2 stroke engine isn't that heavy.
If you're making boost regardless of the extra weight you will be making more power.
This is actually a really good idea, I could totally envision a little lawn mower engine in the back hatch rigged up with custom exhaust plumbed into the cars exhaust or something.
