koni strut insert
nobodyhere671
koni strut insert
Post by nobodyhere671 »
http://performance.yoparts.com/koni/kon ... 52036.aspx" onclick="window.open(this.href);return false;
would it be possible to make any of these work on my mx3, and if so how would i go about making it fit?
Re: koni strut insert
Post by wytbishop »
Koni inserts are universal and install into your existing strut body. Instructions are included with the product and there are several how to's ...like this one for example...http://www.druidhillroad.com/projects/koni/" onclick="window.open(this.href);return false;
You do have to get the correct one for your strut. I'm not sure which one that is, but it's not new information.
Yep
Need to use the stock struts as a type of housing/mount since the Koni's literally go inside.
(doh you beat me to it)
I got mine from Corksport.
http://corksport.com/store/category/53g ... hocks.html" onclick="window.open(this.href);return false;
nobodyhere671
does anyone know the inside depth and inside diameter of the strut housing?, i'd take mine off and apart to
measure it but i can't really have down time since im using it to go back and forth from work right now
also, should i buy one with a stroke close to stock? or would it be okay to get one with a different stroke?
Post by wytbishop »
Buy the ones from Corksport...they've already done the work for you.
