911!!!!! My 1st post and its REALLY important! HELP! 411
What is the black canister looking thing on the passenger side on a K8 5 speed? It has the marking BP01 on it at the top, at first I was freaking out thinking it was my fuel filter cause on my 95 RS MX3 it was in that general area but after searching here I found out where the fuel filter is, under the battery and transmisson area. So before I have to go drive this thing the way it is what is it, because the rubber line running to it and the lines running from it are not connected anymore . Sorry if I didnt give enough info Im very new to the GS model. Premature thank yous to anyone who helps me out.
{FS}93 GS K8 5speed 217,000+ miles, gutted rear seats, factory alloys, BF Goodrich Traction TA, Z01 paint code WR SW Intake
- ElectricEnergy
Re: 911!!!!! My 1st post and its REALLY important! HELP! 411
It sounds to me like your looking at your charcoal canister. I don't think it will hurt anything to drive with it disconnected, but you might smell fuel every now and then. As far as I know it prevents gas fumes from the fuel tank escaping.
I thought it might be that, I remember the one on my 92 SOHC Protege looking a little like that. I really havent smelled any gas though and maybe Im just lucky but percentage wise how sure are you? Im not doubting you, just a little worried still that it could be dangerous. Thank you for the help, I really am intrested in learning everything I can bout these cars since they friggin RULE!
- se7en
lol, ya, that is the charcoal canister. I just removed mine with no consequences.
cheers
7
cheers
7
1992 mx-3 GS-T, 10-12psi, T3/t4 hybrid, Turbosmart WG, AFPR, SSAC TURBO pipes, MSD Blaster coil, K&N, AEM W/B, MSnS(full standalone), 225Whp street tuned(10psi), 245Whp (12psi)(300bhp!!!)
1992 Fairlady Z(JDM RHD) 2+2 TT black(done!)700whp+
Don't Click Here! Trust me,Time waster!
Wow, what a relief, LOL. But again u guys rock! How hard is it to remove se7en? I didnt really mess with it since I thought it was needed, but why would u remove it? Just to save some weight? Also I noticed a line running from the EGR going to the air intake was not connected, so I reconnected it and was wondering if that was a bad idea? Any other Ghetto AKA cheap mods I can do? I was starting to remove all sound deadning from the engine area since I read on here that this motor, K8 dosent run well once it gets kinda warm. Also removed the jack, and all parts of rear seats. I tryed to remove the spare but it seems to be rusted down in there like for eternity,lol but I guess I could get it sawed off or maybe torched off and then remove the bolt holding the spare down? Sorry for typing so much, Im just really happy to be zoom zooming around in a V6 MX3 now.
- se7en
well, I removed the canister in an attempt to clean up the engine bay...about the egr stuff...I don't know, as I don't have egr anymore...
I am running the megasquirt standalone fuel and spark setup, so I don't need most of the wires, and hoses that transverse our engine bays
7
7
If you are in Ontario, pray that they do not decide to bring your car in for a "random inspection" if you ever get pulled over >_>se7en wrote:lol, ya, that is the charcoal canister. I just removed mine with no consequences.
cheers
7
- umcamara
There's a vacuum line going to the canister. If you just disconnect the hoses without plugging that line, you will have a vacuum leak.
- se7en
no s---
lol Just buggin you umcamera lol
but ya, don't worry, I plugged that vacuum port
hmm maybe thats why when i slow down to a light i start to smell a weird fuel/burnt/oil smell, or is that just my rings haha burning oil?
1993 Mazda MX-3 GS, V6 KLZE 2.5L, CenterForce Duel Friction Clutch, Nylon Shifter Bushings (from Imazda.com), Integra Cold Air Intake, Millenia Intake Manifold, Indigo Gauges, Pacesetter Header->Resonator->2.5" piping->Dynomax Muffler, VSX Front and back bumpers from FX Designs, AWR Front and back Motor Mounts.
What benifit is there to disconnecting this. It's in place to protect our environment, you've heard of green house gasses. I'm not some nut for this stuff but if there's no benifit to disconnecting it then why not leave it be? Just a thought.
doesnt the canister collect gas vapours and recylce them back into the intake? that would mean removing it would allow vapours to freely seep in the engine bay no? sounds a lil riskAy..on another note, can somebody tell me more about this megasquirt stand alone system?? ?
Its all covered in the Engine Electronics/Tuning section and you can also check out probetalk.com and search for it on there, they are more in dept with the system over there.tmac4t4 wrote:can somebody tell me more about this megasquirt stand alone system?? ?
yeah I removed mine and it had no negative effects. But it wasnt connected to begin with, so I cant say do it or dont I just know it wont make the car run better or worse but if you need the engine space I say go ahead and chuck it! Again thanks for the quick reply and info it was a little scary for me at the start,lol.
