total weight of UR MX-3
- Limegreen mx-3
Re: total weight of UR MX-3
hum interesting
where theres a will theres a way..
if there was a turbo V6 model weight in 2200 +- s--- OMG i don't even what to know what kind of times it would pull..
im trying to get into the 2000 lbs weight area..
but good luck on getting there..
props on weighing in the 2300 lbs area..
WHAT! i always thought our cars weighed around 2800LBS!!
1993 Mazda MX-3 GS, V6 KLZE 2.5L, CenterForce Duel Friction Clutch, Nylon Shifter Bushings (from Imazda.com), Integra Cold Air Intake, Millenia Intake Manifold, Indigo Gauges, Pacesetter Header->Resonator->2.5" piping->Dynomax Muffler, VSX Front and back bumpers from FX Designs, AWR Front and back Motor Mounts.
- XxantwawnxX
Wonder what mines weighs : P
yes i cut out the tire well....to much extra weight haha
look at that fancy wiring and that top of the line NARROW BAND wooo
and i got a plexiglass hatch..that saved a tooon
and the passenger door does not need a support beam!!! crazyness
- Limegreen mx-3
about time there are the daring crazy mazda mx-3 guys that are willing to do crazy radical setups..
I thought i was the only one willing to go to such extremes.
good job XxantwawnxX
Now u have to do something about that narrow band..
XxantwawnxX, i cant believe you have the tar insulation on the floor still!!!! i took all mine out the last 3 days and i weighed it. The whole front weights about 12lbs, firewall insulation weights 9lbs est., and the rear weights about 6lbs thats a total of 27lbs of unused weight on your car still LOL! I will have pics off mine up soon!
- fowljesse
Antwawn, did you buy the Plexiglass, or make it? If you made, it, did you just form it over the window with a torch, and where did you get it?
- XxantwawnxX
believe it or not i bought it off ebay...some guy happened to have a racing MX3 shell....with the fiberglass hood(extra light and thin) and the plexiglass hatch. I snatched it up before anyone found out about it haha. the glass hatch was close to 100 pounds i think mine weighed in at like 20 or 25.
- fowljesse
Great, now I'm going to be addicted to Ebay, again
No wheel well, tar, insulation, carpet, custom dash, a/c head delete, custom body harness....
- Limegreen mx-3
damn im i so glad i don't do things within REASON,..
if u know what i mean..
thumbs up to u 2 guys for ur weight reduction
LOOKing damn sweet...
- XxantwawnxX
im gonna try to weigh mine tomorrow : )
- fowljesse
I am very interested! Also, what is your HP?
If for any reason you want to sell the 'glass, or hood, lemme know.
- XxantwawnxX
Well official weight says it is 2030 pounds (scale is accurate for about 20 pounds give or take)
so if i switch my racing battery in id be just about under 2000 pounds deff if i get rid of the insulation.
and no im not planningon selling the hood or the plex hatch. : P
I never had it dyno tuned or anything so i dont know the HP : (
OMG!!!!! you have to get it under 2000 that would be sick!!!
- XxantwawnxX
mazdamx3freak wrote:OMG!!!!! you have to get it under 2000 that would be sick!!!
well only 30 pounds to go i think its very possible haha i wanna be under 2000 so bad.
