Apexi S-AFC
JET30X
Apexi S-AFC
Post by JET30X »
Thinking about buying one for my mx3. Anyone of you guys recommend them ? one of my mates has one on his FTO n said it made a fair bit of a difference, plus it looks cool.
looking at getting one like this - cheap off ebay
The item ends really soon so let me know :D
solo_ryder
Re: Apexi S-AFC
Post by solo_ryder »
V6 or 4cyl?
If it is a v6 model that you have I would not recommend it as one you hit the gas at full throttle the SAFC will be ignored as the ecu runs a pre made program to run rich (at about 13.7 A/F) when you go WOT. Unless you modify your throttle body to only open 90% of the way (the ecu cannot sense WOT), then they will not help you that much.
tehbrookzorz
Re: Apexi S-AFC
Post by tehbrookzorz »
solo_ryder wrote:V6 or 4cyl?
X2
Cody
JET30X
Re: Apexi S-AFC
Post by JET30X »
ah ok, yeah mines a v6. why the hell does he hav it on the fto then? its v6 as well
Stablo87
Re: Apexi S-AFC
Post by Stablo87 »
What about the Smt-6?
solo_ryder
Re: Apexi S-AFC
Well the FTO is a totally different car with a mitsu ecu. Does not function like a mx3 v6
solo_ryder
Re: Apexi S-AFC
Stablo87 wrote:What about the Smt-6?
I have never seen anyone try that on one of our motors. If you are going to tune, use MSNS as it is well documented with our V6 engines and it can actually work with our ECU's as a piggyback or standalone
JET30X
Re: Apexi S-AFC
Post by JET30X »
how much of a gain wud i be looking at? i just put on a K&N pod filter thats about it for engine mods
solo_ryder
Re: Apexi S-AFC
Probably not a whole lot, if you use megasquirt on a 1.8L v6 you may yeild 10hp
tehbrookzorz
Re: Apexi S-AFC
Sounds like S-AFC wouldn't be much use to you even if it did work with our cars. Most people only use them on turbocharged applications.
Cody
