I'm currently in the process of tracking down a KL-ZE for my 94 GS, and while I'm tracking it down I thought, hey, why not do some other mods that I'm going to need for my ZE anyways.
Here's my question:
What size of pipe should I run under the car for the ZE? I've heard 2.5" but I want to confirm this. I'm planning on running a tanabe tuner street medallion muffler too.
Also, If I have 2.5" pipe with this new muffler on my K8 before I swap, will I lose power?
Thanks.
Oh one more thing. Clutch question. I'm planning on going with an ACT, and as far as I know I need the one for the K8 Engine (MX-3) correct? Like i'm not swapping the tranny, just the engine, so when I'm searching the site for my clutch I should be looking for the 1.8L V6 Clutch and not the 2.5L V6 clutch for, say an MX-6, or does it even really make a difference?
Thanks again.
Exhaust
- Kirk95gs
Re: Exhaust
A general rule for exhaust is 1" for 1 liter of engine. So 2.5"/2.25 is right for a klze. it wont hurt the k8 to run the same also if your planing on a swap. I ran it for 4 years befor I completed mine.
And you can run the 2.5 v6 mx6/probe clutch on the k8. If you are installing a ze then you will need this clutch cause the stock 1.8 will not hold up for long. the probe/mx6 clutch will work fine on the k8 G serires trans.
Re: Exhaust
go 2.5 full mandrel.its a v6(big engine) ,im going 2.5 to 3" on mine ,only got bolt ons.(ze)yeah its N/A
Re: Exhaust
it really doesn't matter on the exhaust as there really is no way to control the back pressure on these engines because of the VRIS. Id go with a 2 1/4 to 2 1/2 nothing bigger though, and a nice resonator no catalytic converter if you don't need to pass any emissions thing where you live.
And about the clutch you should go with a stronger clutch as the K8 one wouldn't hold very long with he new found HP and TQ. Go with one from a MX-6 as they fit the same and the pressure plate is about 10mm bigger then a MX-3 one.
1993 Mazda MX-3 GS, V6 KLZE 2.5L, CenterForce Duel Friction Clutch, Nylon Shifter Bushings (from Imazda.com), Integra Cold Air Intake, Millenia Intake Manifold, Indigo Gauges, Pacesetter Header->Resonator->2.5" piping->Dynomax Muffler, VSX Front and back bumpers from FX Designs, AWR Front and back Motor Mounts.
Re: Exhaust
I agree...no more than 2.5" and you should know that you will lose all of the bottom end if you use that on your K8 until you get the ZE in there.
