Ok, so to run the risk of coming off as a total ricer, here goes nothing...
I love the look of gauges in a car. I'm not talking about the three foot diameter tachs with a shift like that is as bright as a nuclear holocaust, but like the 2 1/16" diameter ones (boost, volts, oil pressure, a/f ratio, etc).
I plan on boosting the car, but not for another year or so, and obviously have no need for boost gauges.
I guess my question is; are there any gauges that could be considered beneficial for a N/A engine? Forgive my ignorance, but I'd love to put in some gauges but don't want a couple of useless things that look pretty.
Gauges?
- umcamara
Re: Gauges?
Vacuum gauge... FTW.
Re: Gauges?
a/f meter ![Wink :wink:](./images/smilies/icon_wink.gif)
K8 :: 136.8 bhp---160 nm---108.0 whp---118lbs/torque
ET: 15.567 @ 136 kmh (84 mph)
![Image](http://img148.imageshack.us/img148/79/rx78tqdv4.png)
"Racing a Honda is like being in the special Olympics, you may win, but in the end your still retarded."
Re: Gauges?
Oil pressure, water temperature, oil temperature
- RS_OBD'oh_2
Re: Gauges?
Hells ya. You will need the vac/boost guage in the future anyways. My pillar is sporting AEM boost guage/controller and AEM UEGO.umcamara wrote:Vacuum gauge... FTW.
Re: Gauges?
I too like the look of gauges, but in hindsight I wish I had gotten different ones... I have volts (which has actually proved useful several times), a/f ratio (only because it looks cool) and I modified a single shift light to fit in the bottom hole.
If I were to get more gauges or replace the ones I have, I would get vacuum and oil pressure which would prove useful in the klze.
![Image](http://i806.photobucket.com/albums/yy344/Mooneggz/laguna_seca_signature.jpg)
Re: Gauges?
This is perfect. I'm trying to avoid exactly this, getting gauges because they look cool, only to regret not getting gauges that actually serve a purpose.Mooneggs wrote:I too like the look of gauges, but in hindsight I wish I had gotten different ones... I have volts (which has actually proved useful several times), a/f ratio (only because it looks cool) and I modified a single shift light to fit in the bottom hole.
Keep the replies coming... what gauges you have, which would be useful....
'94 GS-DE
Re: Gauges?
Volts and oil pressure for sure since there aren't factory gauges for those. You don't really need a temp gauge since there is a factory gauge for that. If you do plan on boosting in the future, go ahead and put in the boost/vacuum gauge while you are already installing gauges.
No more MX-3
2005 Hyundai Tiburon GT
95 F-150...6" lift, 35" tires
