Clear corners
- Mx3Baker
Clear corners
Just wondering if everyone buys there clear corners off ebay and or if they come with all side marker lenses example. 4 front bumper and 2 rear bumper.. Thanks
93 Mx-3 GS
5 SPD Conversion
Worklog at
viewtopic.php?f=46&t=54796" onclick="window.open(this.href);return false;
5 SPD Conversion
Worklog at
Re: Clear corners
Usually you but the clear corners as a package (the two front turn signals), then the side markers (comes with 4). Ebay only has the corners, you can get the side markers off corksport i think, but you can also just get the miata ones and modify them to fit, which is what I did.
- Mx3Baker
Re: Clear corners
i wonder how it would look if i shaved the side markers front and back bumper and if i only hav the turn signals up front or if its legal or not?
93 Mx-3 GS
5 SPD Conversion
Worklog at
5 SPD Conversion
Worklog at
Re: Clear corners
All of them should be the same, 1990-2005 i believe. Here are the ones i bought: http://cgi.ebay.ca/90-05-MAZDA-MIATA-CL ... dZViewItemrekognize wrote:Miata sidemarkers will work? What year?
They stick out a tiny bit in some spots, because the backing is shaped differently, but if you take off the lens and use it with the stock ones they are perfect.
