Clear corners
Mx3Baker
Clear corners
Post by Mx3Baker »
Just wondering if everyone buys there clear corners off ebay and or if they come with all side marker lenses example. 4 front bumper and 2 rear bumper.. Thanks
93 Mx-3 GS
5 SPD Conversion
Worklog at
viewtopic.php?f=46&t=54796" onclick="window.open(this.href);return false;
matt753
Re: Clear corners
Post by matt753 »
Usually you but the clear corners as a package (the two front turn signals), then the side markers (comes with 4). Ebay only has the corners, you can get the side markers off corksport i think, but you can also just get the miata ones and modify them to fit, which is what I did.
rekognize
Re: Clear corners
Post by rekognize »
Miata sidemarkers will work? What year?
Mx3Baker
Re: Clear corners
Post by Mx3Baker »
i wonder how it would look if i shaved the side markers front and back bumper and if i only hav the turn signals up front or if its legal or not?
93 Mx-3 GS
5 SPD Conversion
Worklog at
matt753
Re: Clear corners
Post by matt753 »
rekognize wrote:Miata sidemarkers will work? What year?
All of them should be the same, 1990-2005 i believe. Here are the ones i bought: http://cgi.ebay.ca/90-05-MAZDA-MIATA-CL ... dZViewItem
They stick out a tiny bit in some spots, because the backing is shaped differently, but if you take off the lens and use it with the stock ones they are perfect.
Return to “Appearance”
