1. First thing i noticed , before i turn to start when you have the lights on the dash , the engine chek is not lighting.
2. the engine seems to .. shake when iddle at normal,then when i rev and let the acceleration when it drops to 1k it stays a little bit then drops down but it makes like a kangoroo till it calibrates ..
3. Around the right engine bay there is a buzzz its like electricity at high voltage lol ..
4. When i shift in first gear the RPM drops very LOW , instead of increasing to 1k .. i think if i dont put gas the engine dies.
5.The gas smell changed , comes some strange smell inside the car lol.
Pro:
1. The only thing ive noticed is shifting .. became much easier to syncronize the rpm when shifting , with the K8 ecu rpm dropeed so fast that it was hard to have same rpm when shifting.. with this one woow !
2. I was not sure but engine pulls better, right now is some snow with salts on the roads , i cannot check anything .
3. Engine sounds better , exhaust also.
I am sure i can make it be good , it will run like a charm .. but what is the problem ?
why it decrease rpm when shifting ? i cannot let her alone cause it will stall> with the other ecu if i let her alone it was going with almost 1k in second gear..
I think the ignition wires has to be changed ... :\
The timing belt ?
what else could cause this ? please guys i want to finish it this evening :\ thank you , youre the best!
