KL96 KLB6 ECU?
KL96 KLB6 ECU?
Apparently these are taken from Eunos 800's with KLZE's. Any Idea if these will work? The guy tells me it's a rare ECU and it works in a Probe GT. I checked with the forums first and someone mentioned something about it but they weren't clear on if it works. Think it's just for an Automatic and will work fine? Could be out of a new model.
KL96 or KLB6.
KL96 or KLB6.
- Kirk95gs
I dont think it will work .... I dont know why but I think it was tried in a mx-3....
Check out this link..
not a lot of help but it is something..
http://forums.probetalk.com/showthread. ... light=kl96
- mx3autozam
Whats wrong with probinator? I have been using mine since i first had my ze and it runs good.
-hec
- mx3autozam
- WhiteFinish
I talked with the guy from probinator and he said the results for mx-3's often turn out bad. You sure? The chip I'm soldering in is NOT from probinator. The probinator I've seen is an entire ECU that has been flashed. Also, I have a 92 GS. I heard the 92's are just a little different in some ways. But then again, maybe it's just B.S.
I got a Probinator chip in my car and it runs perfect even better than any ECU/VAF combo and I've used all combos. You might have a problem with getting it done on your '92 ECU though. I didnt have that problem cause my MX is a '93.
1993 Mazda RX-7 Touring Edition Innocent Blue Mica- Not stock...
1993 Teal MX-3 GS- KLZE and other goodies. RIP
- sk8erdude802
What the probinator deal is is that you send him ur ECU and he puts a socket in it and puts a new chip in it. You can buy the chip from him but its only abit more for him to do it. Hes a pretty good guy. I had him chip the ECU from my dead se in hopes to go ZE one day.
Steve-O
Steve-O
93' MX-3 GS SE ZE - Sold to Acheron1502! SOLD!!!
93' MX-3 GS SE - R.I.P. K8 with Integra CAI, HEI mod, Koni inserts with H&R's,drift kit, Kicker KX400.1 and KX200.2 amps, 2 kicker 12s, set of 6x9's. Custom trunk enclosure
MyFeedBackThread
^^^^^ Click on image for my work log ^^^^^
MyFeedBackThread
I think some of the earlier models use a slightly different ECU, which Probinator cannot chip, since his chips are designed for Probe GT. If you send him your chip number, he'll be able to tell you if it can be done or not.
I'd be weary of non-Probinator chips, since they haven't been tested much and who knows what they do or where they come from. Probinator chips have been proven to perform well.
Well, that's been pretty much gathered is that the early 92 ECU's use a full-length PCB board on the top, while the later 92's and up use a 2/3 length. My original ECU from my Mx-3 was the full length, but I got an ECU off of eBay for $15, that was 2/3 length, I chipped it with a probinator and it worked. If that's true or not, we're not sure, but it seems to hold true; so basically if you pop off the top cover and the PCB board right on top there doesn't span the whole length, than it should be chippable. Ideally you want to get the # off the chip and ask the Probinator guy, he'll let you know, but so far so good on the rule of thumb.Whisper wrote:I think some of the earlier models use a slightly different ECU, which Probinator cannot chip, since his chips are designed for Probe GT. If you send him your chip number, he'll be able to tell you if it can be done or not.
As well, why risk getting an unknown chip when you know that a tried-and-true solution works.
