(FS) 95 modded KL-ZE engine
mazdaspeedmx_3
Post by mazdaspeedmx_3 »
i need money to finish my rx7 project
95 JDM Curvedneck KL-ZE 90,000kms
Swapped in KL-31 cams rebuilt and cleaned HLA's and Lifters
lightweight crank pulley
port & polished IM with knife edged behind TB
Accel performance HEI module
MSD blaster 3 coil
chipped KL-07 ECU
new mazda timing belt tensioner
this engine runs consistant low 14's
205psi of compression in all cylinders this is a strong engine
http://www.cardomain.com/member_pages/s ... 7_full.jpg
$1000
or $1400 installed
2006 best ET 14.43 @ 96.9mph
93 MX-3 GS-95 Curveneck klze, kl-01 cammed,homemade CAI,HEI module, chipped kl-07 ECU,UDP,KYB GR-2 struts,DropZone lowering springs, Toyo Proxes 4's 205-50-r15
parts to be installed:Turbo hot pipes,T04E/t3 50/63 57 trim, ssqv BOV, hks style 38mm wastegate
the rest of my turbo set up and IPP hp rebuild kit is in the NEAR future
SOON TO BE MX-3ZE-T
Bling Bling
Post by Bling Bling »
Where is St. Thomas? Canada? hmmm lets's see what we could do....
Will it need anything or will I be able to just drop it in? And are there any signs of oil or coolant leaks?
Stacy Whitrick
MX-West Calgary
http://www.cardomain.com/ride/1335558 UPDATED June 6,07
94 GS, Green Envy Pearl QUESTION: Does my car fit the RICE category?
mitmaks
Post by mitmaks »
wish it was closer
mazdaspeedmx_3
i put a new water pump on it last year,,,theres no leaks whatsoever on the engine
just bolt it down plug it in and go
SOON TO BE MX-3ZE-T
