Yea i just assumed he was talking about KL'sRbluE_MX-6 wrote:K series are aluminum blocks, and B series are iron blocks. Just toXxantwawnxX wrote:Aluminum block also.Open_dump wrote:i thought mx-3's were iron block aluminum heads?
clarify.
Meth/Alcohol Injection
- XxantwawnxX
