my car is in the garage for its stalling problem
car was accelerating to around 3k rpm then stalling as if the rev limiter had been hit or the fuel mix just completely went wrong, but only under load. Been trying to do research into this and have a look around and come up with a few ideas. Any more are welcome.
Problem is the dash board has no hole for the light for the engine codes to flash up. My mechanis has tried to bridge the diagnostics port in the engine bay but cannot get any readings out of it so is finding it hard to source a problem
Any ideas?? How should this be done, and is there any other way of looking for codes out of this port??? Ideas on the stalling problem are also welcome!
No Diagnostic Output.. ??? KLZE Stalling at 3k rpm
hgallegos915
Check out the faq pages. What ecu? remember that the ze ecu wont have a cel for codes. You nbeed to use a led light to get the codes.
-hec
- ScooterBovine
hgallegos915
ohhhhh they use leds?
-hec
timpronk
One easy thing to check would be if you have a rip in your air intake tubes. The hoses between the throttle body and air filter.
It is possible that when you give the car gas, the motor tilts just enough at around 3000 rpm that it spreads the rip open (if after the vaf) and lets in un-metered air, causing the car to stall.
Just a thought, and easy to check.
Also there is known issues with the distributor dying. Which has a similar symptom to what you describe. Only that it is not always consistent.
I have had both of these problems in the past, and they both will make your car not run at times.
Has your ze ever ran perfect? Or have you just installed the ze and it has this issue from day 1?
92 MX-3 GS 2.5 KLZE
14.385 @ 98.21
14.385 @ 98.21
the car ran fine whilst running on the original k8 ECU for around 6 weeks after conversion. I swapped over the ECU's to a KL31 and around 2 weeks later I found problems.
Looking into the dizzy now, I'm told the dizzy is the part which holds the rev limiter in?? if the dizzy is faulty then this would make sense so trying to find another dizzy from a v6 mazda. Used the dizzy from my old engine so I know it worked before hand
