Complete Miata Cam swap for B6, everything I need?
zoom_zoom94mx3
Post by zoom_zoom94mx3 »
thats awesome! thanks jon, hey when you do go through with the swap, do you think you could take some pics?
94 mazda mx3 rs 1.6l DOHC... probe 4-2-1 header, 2" catback, a spec CAI, advanced ignition timing, NGK plugs/ wires, obx light wight crank pulley
http://www.cardomain.com/ride/2754605/1
Bumpysbro
Post by Bumpysbro »
ya sure would be glad to. if you have any trouble theres a guy on here named "Josh" he was the first to do the swap and he would probably be able to help you out more if you run into anything. best of luck :2thumbsup:
1995 mazda Mx-3 RS 1.6liter DOHC B6-DE
SuperK
Post by SuperK »
I need some opinions.
OBX's specs on their cams are:
Stage 1: Duration (Lift mm): IN. 256, 9.0; EX. 256, 9.0
Stage 2: Duration (Lift mm): IN. 264, 9.0; EX. 264, 9.0
Integral's specs on theirs are:
Stage 1 248° .343" (8.71 mm)
Stage 2 254° .360" (9.14 mm)
Stage 3 260° .375" (9.52 mm)
Does anyone have an opinion of which is the best application without changing the valvetrain?
I THINK that the OBX would be a better bet, having not as high a lift, but I'm not sure what the duration is going to affect? Them stage 2's have a longer duration than Integral's stage 3's.
Opinions welcome, desired, wanted!
zoom_zoom94mx3
well those obx ones are the ones that i am planning on buying as well, and while i may not have have any experience with the quality of their cams, i do have an under drive pulley from them and i love it!
Spotted
Post by Spotted »
Do you think one of you guys could possibly document all your work with pics and stuff so that others can follow in your path? They say there are write ups here in the forums, but I can't even seem to find them. Perhaps it could get stickied once done!!
I dont know....
:welder:
Limegreen mx-3
Post by Limegreen mx-3 »
anything above a stage 2 camshafts and ur going to have to upgrade ur valvetrain..
stage 2 and below u'll be fine with the OEM valve train.
