Fan Still Doesn't Work - Tried Sooo Many Things
Hey guys
So i realized my coolant has been leaking from the top, which then i noticed my fan would not turn on. I tried so many things and it still doesn't work. Ill list them:
-changed radiator cap
-changed thermostat
-changed oil filter
-changed engine coolant temp. sensor
-connected fan to battery, and it worked
-tested the fan relay as it says in shop manual and fan relay works
-flushed out all coolant and new clean one is in
Thats all I can thing of that I can do. I don't wanna send my car to a mechanic and gotta pay 200 bucks on something I could've done myself. So anyone got any other ideas I can try?
Thanks a lot
-changed thermostat
-changed oil filter
Thanks a lot
Isn't there a fuse for the fan?
![Image](http://i806.photobucket.com/albums/yy344/Mooneggz/laguna_seca_signature.jpg)
are you sure you replaced the correct temp sensor?
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
- mx3autozam
- mx3autozam
- tehbrookzorz
why dont you wire it to the battery and see if its the fan? If all fails. wire them to a switch. I got both fans wired to switches. For drag racing (at the line) I turn both of them.
-hec
- 94mx3precidia
- 94mx3precidia
