Ignition Module Maybe??? Please Clarify.
Hey Guys,
Laugh it up...I've never owned a car. I thought I did enough research before buying my car...but apparently not. I own a 94 MX3 Precidia. Immediatly started overheating. Luckily I figured that one out and only had to replace my thermostat. But now its been off the road for about a month and my boyfriend and Landlord keep looking at it and basicly i keep relplacing parts that are not doing anything. So i am now taking it to my own hands and am hoping you all can help.
Heres what I do know.
I was driving and everything locked and shut down on me. Power steering, brakes, and gas. And would not turn over. Had to push it back to my house.
I am getting no spark.
I replaced the spark plugs, they were pretty bad. And what my landlord thinks is called a cam centre was full of rust so that was cleaned up. Unfortunatley that did nothing.
I've been reading tons of these threads and forums and i think it might be the ignition module. But again i've put alot of money into this car already, and don't want to go on "could be this or that" anymore. Please help me out.
Thanks so much.
Thanks so much.
- Tunes67
First thing to do is check CEL codes (This is assuming you live in North America since other locations may not have the CEL)
Do a bit of searching for CEL Codes and you will find out how to do this. That will give you a lot more of a difinative answer off the bat. Cheers
Tunes67
P.S. If after searching you still have questions.. I can do a more descriptive answer.. but all this information has been discussed hundreds of times.
Tunes67
I have no idea what a CEL Code is. But i did look into it and found this website
http://www.atlantamx3.com/mocaforum/vie ... 06658ea03b
Is this what im looking for?
thanks again
thanks again
- Tunes67
A CEL code is a Check Engine Light Code. And yes that is a table of CEL codes for our V6 Cars. The CEL is on the dash to the left side of the speedometer. You will see it light up and go off when you first start your car. That page gives all the info you need to pull your CEL code(s) if you have any present and will even tell you what code means what. Hope this helps.
Tunes67
Tunes67
- Tunes67
Well if I am reading that right.. you have codes
03
08
09
(the first 1 slow is a seperator)
24
What that translates into is
03 camshaft position sensor - this is the one that is probably preventing your car from running. Typical when the distributor is going out.
08 Volumn Air Flow Sensor - These rarely go bad.. its more likely the plug is lose. If it is bad.. find one used cause a new one will cost $600 or so.
09 Coolant temp sensor - these seem to go bad fairly often so this isnt a surprise.. if you were having idle issues.. this was the likely culprit
24 RHO2S inversion error - This is usually O2 sensor related.. but not always. I "Think" this is the code for the rear O2 sensor. I am sure others here will correct me if I am wrong.
Bottom line.. thats a lot of codes to throw at once.. I would clear the ECU and see if the car starts. To clear the ECU.. disconnect the battery for at least 5 minutes and then pump the break pedal 2-3 times. Then reconnect the battery and see if the engine will start. Then check codes again to see if the same codes throw a second time.
Cheers
Tunes67
03
08
09
24
Cheers
Tunes67
I just found out that my landlord was looking at my car earlier and had disconnected the air filter and a bigger section connected to it. I don't know if that would've affected any of the codes. But i am going to go reconnect that and i'll try the battery thing. thanks
Hopefully this works. Crossing fingers.
- Tunes67
That was your code 08. Good thing too.. thats a spendy part to replace LOL
Tunes67
Tunes67
- Tunes67
Basically it means the ECU isnt getting an error code from the faulty device(s). Even if the car doesnt start.. it should still throw error codes when you try to crank it over.
Tunes67
Tunes67
