what mass airflow meter bpt ecu and wireharness
I would appreciate some help here I have a bpt ecu wireharness and mass airflow meter but the mass airflow meter is damaged what mass airflow meter can I use and from what mazda. I have read that you can use an rx7 meter but I dont know what year model I should use turbo or n/a, what about the protege 1.8 bp can this work and from which model
1995 J-Spec Az3, BPT swap, mazda speed eibach springs, mazda speed swaybars, mazda speed exhaust, mazda speed shock tower bar, mazda speed bodykit, sr shocks, disk-brakes all around,turbox boost controler, honda del sol act pressure plate, fmic 20x12x3
- mazdax3speed
- cyclonekid78
If you set the RX7 vaf up right you wont run rich. But with the BPT ecu and boost controller you should set it up to run a little rich so there is no lean effect.
93 RS BPTurbo
http://www.cardomain.com/ride/2628805" onclick="window.open(this.href);return false;
