maf options
maf options
I have read that an rx7 maf from the n/a version can work on bps but what options do I have for a bpt using the bpt harness ecu and where can i find a replacement
1995 J-Spec Az3, BPT swap, mazda speed eibach springs, mazda speed swaybars, mazda speed exhaust, mazda speed shock tower bar, mazda speed bodykit, sr shocks, disk-brakes all around,turbox boost controler, honda del sol act pressure plate, fmic 20x12x3
I have heard that the rx7 n/a and rx7 turbo second generation maf sesnsor can be used on the bp
Is this true if not what exactly can i use to replace my maf and what vehicle and year is it
what about the protege lx airflow meter can this work
- mr1in6billion
I've never understood the point of the rx7 swap. The thing is bigger and supposedly flows better, but it's still a trap door which is restrictive and it's a pain to have to retune it to work with anything other than an rx7. If you really are into changing it out get a map or at least a newer hotwire and use an afc to adapt it.
Am changing mine because it isnt working properly so I need to know what replacement there is that can work and from what cars.
- mazdax3speed
the rx7 will work with out any change to it, but will run hella rich. ive been using it simply because you cant find a BPT MAF anywhere
its not just because its a bigger opening, but it sends for more fuel for the amount of air....because its from a rotary....and they suck gas like its goin out of style, so if you dont mess with it itll run rich, i havent adjusted mine because i dont really know how to
Orange 95' BPT GT28r, MSII on the way
how long have u been using it, running too rich can affect the life of your engine have it adjusted because too much fuel will affect the power you make.
