Koni Adjustable Inserts - Damping Rate? All Handling Info?
Hello Guys, i have Dropzone Coilovers (modified correctly to work safely as standard kit was pointless)
I also have Koni 15 point Adjustable inserts (not top adjustable - sucks) The Spring rates are rear 350lb and front 450lb
Has anyone experimened for a good handling setup as to adjust the damping rate you have to fully depress the shock and twist the hydraulic rod. As this would be time consuming to do has anyone already done it for optimum handling. What would you guys recomend?
Rear Link bar too? ARB's? I have used the search but confused myself. So many people do many different things, what mods are gimmics and what works?
I have stripped out my ZE and woud also like a nice chunky polished rear strut brace, who makes the sexiest one?
Many Thanks, Tom
Many Thanks, Tom
No problem
It`s not overkill at all, it`s stiff, but it`s really fun to drive
Also, I can really recommend the Whiteline rear swaybar.
Thats a really high quality part thats reasonably cheap, and gives awesome handling.
I think I got a decent suspension setup on mine.
http://www.nope.no/index.php?page=car
-n
-n
:: 2001 Mazda Mx-5 Sport // 2013 Volvo V40 D2 Momentum ::
- JM1EC-V6
just installed them on my GS today, and without a road test, they seem much more softer than KYB GR-2's.
And of course, they're not compression adjustable, just rebound adjustable.
Do you guys have the same impression ?
'94 Mx-3 GS-R SE, KL-ZE Interprep. (From '96 PGT KL)
1110Kg
-Interprep KL31 Spec.
ported heads, Polished combustion chamber,3 angle vlv job,10.3:1 C.R.,0.020'' O.S.,KL31 cam,-0.007'' heads,Long neck IM,KL31 TB, Hotshot headers,2.25'' exhaust,Magnaflow cat
1110Kg
- JM1EC-V6
After my road test, the conclusion is:
The car is 1.5 times better in handling while being more comfortable.
The rear is softer in compression though. The GR-2's are stifer in compression than the Koni's, but this makes no difference on how it reacts on the car, except for the comfort.
I'm at 3/4 of the adjustment in the front and rear. I think there's some damage on the mecanism in the rear struts, that's why they're softer. I think i broke the adjustment while adjusting them, they're fragile !
With hand pressure, the back moves much more than with GR-2's.
Is your cars equipped with Koni's are like mine ?
1110Kg
1110Kg
