KFZE install ......vac. and wiring
im installing a kfze for my friend and was wondering if there is anything i really need to chage as far as wiring and vacumn lines goes b/c ive done 2.5 swaps before and everything looks so diff.....
all you need is the jkze ecu. Is it a square runner kf or a round runner? I was using the klde manifold and it was quite good. The k8 manifold was to restrictive compared to the de. stock vaf will do. I wish you luck.. all kf engines that we have swapped ( just 3) we have had bad experiences. Hydrolocks, fires bad engines. Mine amazingly survived all of that.. survived hydrolock and a fire. Power was not that great.
-hec
- solo_ryder
As far as I know there were actually 2 IM's for the KFZE (correct me if I am wrong). The standard KFZE round runner straight neck (hope you don't mind Barry):
![Image](http://i30.photobucket.com/albums/c302/solo_ryder/MVC-001F_mazda.jpg)
And the Type-R Lantis IM, Similar to the K8 but with square ports. THis motor had a bit more HP IIRC (Looks kinda square to me):
![Image](http://i30.photobucket.com/albums/c302/solo_ryder/DSCF0010.jpg)
![Image](http://i30.photobucket.com/albums/c302/solo_ryder/rob_sadler7.jpg)
![Image](http://i30.photobucket.com/albums/c302/solo_ryder/DSCF0004.jpg)
I just noticed that they also came with the cool VC's![Smile :)](./images/smilies/icon_smile.gif)
Not true, the Lantis Type R KFZE came with square ports, and is the true 170bhp motor, the rest are 160-165 rangeJM1EC-V6 wrote:KFZE's are all round runners.
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
- JM1EC-V6
sorry, but you'll need a detailed picture (not a forum blah blah) to tell me this.
The heads on KF-ZE's are K8-1A1 & K8-101
And the ''K8 like'' (Type R) IM isn't squarre port at all.
'94 Mx-3 GS-R SE, KL-ZE Interprep. (From '96 PGT KL)
1110Kg
-Interprep KL31 Spec.
ported heads, Polished combustion chamber,3 angle vlv job,10.3:1 C.R.,0.020'' O.S.,KL31 cam,-0.007'' heads,Long neck IM,KL31 TB, Hotshot headers,2.25'' exhaust,Magnaflow cat
![Image](http://img.photobucket.com/albums/1103/GSRBOMB/MY%20REALISATIONS/th_mazda_mx-3_Raphael_008-1.jpg)
![Image](http://img4.photobucket.com/albums/1103/GSRBOMB/257678_6_full.jpg)
![Image](http://img.photobucket.com/albums/1103/GSRBOMB/Photo013.jpg)
1110Kg
To correct everyone yes the (KF-ZE) lantis Type- R does have square runners ( heads and IM ) with the only 170base hp with the curved neck design. The base model lantis has the straight neck style and round runners. Also the blocks and heads do have K8 on them but also KF engraved on the rear porition of the block As for proof i have the lantis Type-R motor sitting in my garage and if needed i will post pics....JM1EC-V6 wrote:sorry, but you'll need a detailed picture (not a forum blah blah) to tell me this.
- solo_ryder
- JM1EC-V6
Nice, since there's not much infos on these Type-R's, I would be really interested in your pictures & head codes !mazdamx3freak wrote:To correct everyone yes the (KF-ZE) lantis Type- R does have square runners ( heads and IM ) with the only 170base hp with the curved neck design. The base model lantis has the straight neck style and round runners. Also the blocks and heads do have K8 on them but also KF engraved on the rear porition of the block As for proof i have the lantis Type-R motor sitting in my garage and if needed i will post pics....JM1EC-V6 wrote:sorry, but you'll need a detailed picture (not a forum blah blah) to tell me this.
1110Kg
1110Kg
- solo_ryder
Here is a lantis type r. There is a pic of the engine there.JM1EC-V6 wrote:sorry, but you'll need a detailed picture (not a forum blah blah) to tell me this.
http://www.trademe.co.nz/Trade-Me-Motor ... 525351.htm
mazdamx3freak - if you are looking for a kf15 ecu i have one for sale
yeah its teh same swap as a de or klze, ecept you DO need the ecu.. it wont run right with the k8/de/ze ecu.
-hec
Hector knows a lil bout themsolo_ryder wrote:mowambi wrote:I know this is off topic but you do not even know how confused i am now
? We are talking about KFZE's I know that mazdamx3freak wanted to know some info, but as far as I know it should be the same swap. Any questions he has should go to Hector (hgallagos) cause he knows about KF's
hehehe there are 2 others on the board who know them inside and out
Oh if you need any referance pics for anything
http://www.atlantamx3.com/moca/brian/KFZE/
http://www.atlantamx3.com/moca/brian/kfze040104/
http://www.atlantamx3.com/moca/brian/kfze040804/
http://www.atlantamx3.com/moca/brian/kfze040904/
http://www.atlantamx3.com/moca/brian/kfze041004/
I think perry got enough pics
