Need Help!
Need Help!
hey guys i just bought a mx3 v6 with a ZE swap and i was driving today and everything was fine until i jumped on the freeway came off and had to slow down for a stoplight, but as i was slowing down i noticed the car was still revving and i wasnt even touching the gas, and when i came to a complete stop the rpm's raised to about 3k and just stayed there. can anyone tell me whats wrong need to get it fixed asap. thanks in advance.
- MechaManZero
LOL omg sometimes my stock mats would get stuck behind the gas pedal. Sorry. I had the same problem too when I was shifting I was like WTF (thinking in my head "why is the rpms high?")? but found out it was due to my mats moving upward and messing with the gas.
Çlark
![Image](http://i64.photobucket.com/albums/h192/Mechamanzero/MX-3/2mx3.jpg)
95 Mazda MX3 4 Banger
Currently: H&R Lowering springs, BPT from a GTR, 18.5x6x3.5 same side inlet and outlet intercooler, Centerforce Dual Friction clutch
For BPT Frorums - http://www.aokforums.com/mazdaengines/
- MechaManZero
LOL it would be funny if that was the situation though cause I laughed my arss off when I found out what was wrong with my car.
Çlark
94_MX-3 wrote: can you explain how to juump GRND and TEN in the diagnostic box?
![Shocked :shock:](./images/smilies/icon_eek.gif)
Don't adjust your idle without jumping GRD and TEN. Ok, around your battery there shoudl be a black box about 2inch big. Pop that open. ON the top cover, inside the box, there will be a diagram. You'll see a square labeled GRND, and one labeled TEN. Take a paper clip, and stick it in the corresponding squares.
THEN star the car, and adjust the idle. turn off the car, take out the paper clip, and start it again to ensure you set it right.
Did you adjust your TPS yet?
