okay so i just bought a 94 mx3 dohc it has about 145 k's on it..i dont know anything about these cars..Im a Honda and Acura guy now into something different will still into honda's but they to HOT..will my mx3 has a problem when the engine is cold in the morning its about 20 degrees over here..the car seems to burn oil to start with then after a while it seems to run fine...it also has a funny or funky smell to the oil cap and oil but the oil is new...this worrys me about bad piston rings..anybody can help me??i would appeciate it
i would also like to know if there is any kinda special names for the car also.
hey im new to this please tell me what i need to know ..
- PATDIESEL
The car is also known as the Precidia in Canada, Autozam or AZ-3 in Japan.
As for the oil what you are seeing is old seals. AS for what seal there are too many that will let oil into the combustion chamber to tell you about all of them. However, basic engines are all the same in most every way. Therefore, it is likely the piston rings. As the car warms up the seals will expand and close the gap. This is normal in any car of any age, but more prevelant in older cars since the seals, piston walls and other moving parts will have worn making them thinner/smaller than they were when new. The amount of oil being burned is how you will know if it needs to be replaced/fixed. I'd say if it is burning more than a quart between oil changes then it warrant finding the leaky seal. Depending on which seal is bad will tell if it is worth replacing now or just rebuilding the motor when you have the money to do a complete job.
if it's just the valve cover gasket those are around 20 i think and easy to replace just do it yourself and see if that makes the difference
ProjectMx
My BP and AWD build thread
Cardomain
93 Mx-3 GS with bp and GTR AWD system
93 Escort GT daily driving
Cardomain
