mitmaks wrote:got that bumper/lip? sent you pm while ago
Yeh I hae it still. Its torn in the middle, might be repairable though. I was able to mount it as seen in the first picture on the 1st page of this thread, so it isn't too bad.
Its removed & ready to go. I've had a lot of inquiries about it but no one seems to want to buy a torn lip (even tho every one i've ever seen has been torn around the middle where it mounts).
Trevor wrote:Gro How much do you want if you still have them for the Rear lateral Links with the Toe adjustment in them? shiped to L2V 4B8?
Can't remove those..the car has to be a rolling chassis so it can be towed off. Wheels/suspension/brake stuff I can' part out unfortunately (unless i had dollies to rest the car on, which i don't )
anyone snagged the tranny? if not how many miles and how much shipped to 25136
Parts needing installed: turbo kit from BB (if i ever get it), 9.0:1 CR Diamond pistons, 4340 forged H beam rods, C/J-Spec spoiler, Nissan red tops in KL rails http://www.cardomain.com/id/blazejeremy
papa roached wrote:anyone snagged the tranny? if not how many miles and how much shipped to 25136
not going to spend the time to remove the engine/trans so no..its still in the car. It'll probably get crushed with teh rest of the car when they tow it later this week.
Wil, are you getting completely out of the MX thing? I thought you were going to transplant all of your emerald green stuff to the newer acquisition? Hope you're going to stick around? Always enjoyed your expertise, knowledge and of course, the banter.
