There is still a lot more I could remove so REQUEST REQUEST REQUEST!!
UPDATE: I have been receiving quite a few requests for suspension & brake parts. Removing the majority of these parts would make it impossible to secure a wheel to the hub and/or lower the car so much that it'd drag on the ground. Since I need the car to 1: be able to be parked without rolling down my rather steep driveway & 2: be able to roll onto a flatbed towtruck when the time comes for it to get towed off....I simply CAN NOT part these parts out off the cars chassis. If you are local & would rather take the leftover car for its brakes/suspension peices or whatever, then lemme know ASAP. The majority of what I"m willing to part with include: Easily accessable engine parts & stuff under-the-hood, light housings, all interior bits & sensors. Body parts include hood, lip spoiler, rear spoiler, left fender (other one is dented) drivers door, rear bumper, front mudguards, hatchlid & fuel filler door.
Original Post: Hey guys. I'm parting out that Gold MX-3 in its entirety. I had a bunch of buyers for it, but for some reason it won't fit any tow-dolley b/c of clearance issues with the frame, so I figure it'll be better to just part it out for what its worth & get a scrapyard to pick up the remainder of the car once thats over with.
Here's a couple pics of the car:
More located here: http://st85.startlogic.com/%7Eimazdaco/goldmx/
I'll part out any peice of this car with you guys. Only main issue is big things like the Hood, doors, hatch will be PICK UP ONLY.
Door panels & stuff thats bigger I may be able to ship but keep in mind it won't be cheap.
The time frame for this car leaving my property permenantly is pretty short, maybe 2-3 weeks from this post date so don't waste time asking about stuff.
PARTS:
Body peices that are in good shape include: hood, driver fender, driver door, sunroof panel, hatch, fuel filler door, mudguards, rear bumper.
Interior bits that are in good shape include ALL but the following: Front seat has a rip on the seatback, rear seat has a tear in the top, rear seat cushion has a rip at the seam on the bottom passenger cushion (barely noticeable). Otherwise the door panels, dash, plastic trim peices are MINT & flawless...no blatant defects (Ie scratche's burn marks etc).
Engine parts include pretty much everything: JE50 airflow meter, intake mani w/injectors, valve covers, timing covers, intake hose & box assembly, air conditioning parts (the a/c worked, no leaks), starter, etc. I am not willing to take apart the engine too intensively unless the price is right, so make your requests & we'll go from there.
Electrical bits include: full power window system, full power lock system, power seatbelt system, guagecluster with 116.5k miles, radio am/fm cassette, power sunroof, etc.
So Make those requests! I'll do anything! Stupid little s--- like fasteners, screws that secure certain parts, entire systems (power window, or seatbelts), engine parts (distributor, starter, valve cover, manifold, etc) JUST MAKE THOSE REQUESTS!!
Thanks guys.
