HEI On OBDII?
HEI On OBDII?
Posting ou of curiousity and for another Mx-3 member, but is the HEI mod doable on an OBDII Mx-3, and even then, on the newer OBDI models (94-95) is there a difference in the disty wiring for the HEI mod?
max kl
Post by max kl »
i no for shure the distrubtor is diffrent if you like i will look it up at my shop and see how diffrent it is.
JUDGE ME ALL YOU WANT
93 gs, klde swap, kl trans, strait 2.5'' ehaust, euro front bumper, cold air intake, hei ign ,50 shot &
9.60s n the 8th mile so far 8.50s sprayn now
150 shot
mx3autozam
Post by mx3autozam »
yes it can be done on OBDII if you look on Probetralk its on there somewhere. Its not much different than the other one.
John
93 Mazda MX3 KLZE Turbo
max kl
Post by max kl »
it depends on if you have 3 wires going to your coil. if you do than the mod is almost the same. if you only have 2 wires in the 3 pin conncctor than unplug it and check for 3 pins in the coil. if there are 3 than you will have to install the 3rd connector pin.
150 shot
