HEI On OBDII?
HEI On OBDII?
Posting ou of curiousity and for another Mx-3 member, but is the HEI mod doable on an OBDII Mx-3, and even then, on the newer OBDI models (94-95) is there a difference in the disty wiring for the HEI mod?
- mx3autozam
it depends on if you have 3 wires going to your coil. if you do than the mod is almost the same. if you only have 2 wires in the 3 pin conncctor than unplug it and check for 3 pins in the coil. if there are 3 than you will have to install the 3rd connector pin.
JUDGE ME ALL YOU WANT
93 gs, klde swap, kl trans, strait 2.5'' ehaust, euro front bumper, cold air intake, hei ign ,50 shot &
9.60s n the 8th mile so far 8.50s sprayn now
150 shot
150 shot
