14.43 @96.94mph last night haven't changed a thing on engine
Its only gonna get faster guys.....still have an exhaust leak
theres so many factors that come into play i knocked off .25 of a second
and i didn't do a thing...its all in the air and temperature
an incompetant driver can do a number on your time....the funny thing is i totally missed second gear took me 2 tries to get it in and i still ran 15.2 hahahaha tells you something about your drivin eh boyz
reaction--- .8289 if you want a pic of my ET slip email me at
60ft----- 2.1921 mazdaspeedmx_3@hotmail.com
330ft --- 6.1201
et @ 594ft-- 8.7722
1/8th et---- 9.3609
1/8 mph--- 76.45
1/4 et--- 14.4372
1/4 mph-- 96.94
330ft --- 6.1201
et @ 594ft-- 8.7722
1/8th et---- 9.3609
1/8 mph--- 76.45
1/4 et--- 14.4372
1/4 mph-- 96.94
2006 best ET 14.43 @ 96.9mph
93 MX-3 GS-95 Curveneck klze, kl-01 cammed,homemade CAI,HEI module, chipped kl-07 ECU,UDP,KYB GR-2 struts,DropZone lowering springs, Toyo Proxes 4's 205-50-r15
parts to be installed:Turbo hot pipes,T04E/t3 50/63 57 trim, ssqv BOV, hks style 38mm wastegate
the rest of my turbo set up and IPP hp rebuild kit is in the NEAR future
SOON TO BE MX-3ZE-T
SOON TO BE MX-3ZE-T
send pic when your ze blows
-hec
how do you figure its gonna blow buds
i've put over 46000 kms on it
not a single knock or any other irregular sounds
its funny i had always thought a ZE and a DE were different engines
maybe thats why the factory rev limiter on a DE is only 7100 or 7200 rpm
why would the rev limiter be at 8000 stock if the can't even touch low to mid 7000 for a couple seconds![Question :?:](./images/smilies/icon_question.gif)
SOON TO BE MX-3ZE-T
SOON TO BE MX-3ZE-T
I dont know, why dont you call mazda and ask? ![Smile :)](./images/smilies/icon_smile.gif)
-hec
i was tryin to be sarcastic ....buddy there was tellin me about how his buddy blew up his DE cuz he revved it over 7000 rpms
if you drive them right a ZE can hit 7200-7400 rpms in a burn out
i had my ZE with the mx-3 tranny to 235km/h 145mph at 7200 rpms a couple times
drove it 1750 kms a total of 4 times in 2 months in 15 hours flat of a constant 4500-4800rpms at 140 -150 mph came back and ran a 14.43 @96.9 mph....ad it still purrs like a kitten.....
SOON TO BE MX-3ZE-T
SOON TO BE MX-3ZE-T
- fieromx3
Re: 14.43 @96.94mph last night haven't changed a thing on en
ur a cocky mofomazdaspeedmx_3 wrote:the funny thing is i totally missed second gear took me 2 tries to get it in and i still ran 15.2 hahahaha tells you something about your drivin eh boyz
93' MX-3 GS-ZE
14.4 @ 96.7
14.5 @ 97.2
14.4 @ 96.7
14.5 @ 97.2
friggen rights man
I can drive like a mutha f**ker
SOON TO BE MX-3ZE-T
SOON TO BE MX-3ZE-T
- slimmyslim1420
I hit a 9.003 on an 1/8th last night but my reaction time was .161. So if you get your reaction time down, your numbers will be a lot better. Let me know what you get next time you hit the track though. I also wanted to add that I shift out of first at 7500 and second at 7200 just to help mazdaspeedmx_3's point. Car runs fine can handle it all day.
1992 GS ZE swap 94 dash swap drilled and slotted rotors full ceramic pads CS SS clutch and brake lines KL-36 ecu zx-2 tokico struts eibach springs short shifter Tenzo exhaust Hi flow cat 2.5 in piping
- fieromx3
slimmyslim1420 wrote:I hit a 9.003 on an 1/8th last night but my reaction time was .161. So if you get your reaction time down, your numbers will be a lot better.
this is wrong..ur reaction times DO NOT add on to ur overall time at the end! it dont matter if u would have gotten a .783 reaction time ur 1/8 mile time STILL would have been 9.003
93' MX-3 GS-ZE
14.4 @ 96.7
14.5 @ 97.2
14.4 @ 96.7
14.5 @ 97.2
(waits for the BOOM)
-hec
- slimmyslim1420
How do you figure your reaction time dosen't change your end time? To my understanding once the light hits green the timer starts timing. The longer you wait to take off the worse time you will have.fieromx3 wrote:slimmyslim1420 wrote:I hit a 9.003 on an 1/8th last night but my reaction time was .161. So if you get your reaction time down, your numbers will be a lot better.
- slimmyslim1420
Dude why do you care if other people blow up their motor. You shouldn't keep ragging on people just because you don't approve of how they drive their car. You drive how you want and everyone else will drive how they want. The majority of us got a ZE for the power not to baby it! But it is possible for your motor to tear up and never hit 7500, but if mine is going to float a valve or blow up, I would like to get the most out of the it before it does, and have a little fun in the process.hgallegos915 wrote:(waits for the BOOM)
- fieromx3
the timer starts to count as soon as u move once the light turns green to the time u move thats ur reaction time from the time u start moving thats when the counter starts its timing for ur overall 1/8 or 1/4 mile time so next time u go to the track take ur time at the light to get ready for a good run
93' MX-3 GS-ZE
14.4 @ 96.7
14.5 @ 97.2
14.4 @ 96.7
14.5 @ 97.2
- slimmyslim1420
Well thats pretty good I guess. I thought I had some pretty good runs but that one was the lowest. I was trying my hardest to break high 8's. I was at a track thats on a mountain so if i went to one a little closer to sea level I may be able to hit it.fieromx3 wrote:the timer starts to count as soon as u move once the light turns green to the time u move thats ur reaction time from the time u start moving thats when the counter starts its timing for ur overall 1/8 or 1/4 mile time so next time u go to the track take ur time at the light to get ready for a good run
