[FS] low 13 second high 12 second mx-3 parts. PART OUT
Well nitrous took out my motor last night. The car was running low 13's high 12's. Im done with it and am moving on to my RX-7. So heres the list of parts. All parts are in cnd funds and im located in Ottawa, Canada.
- Mx-3 CF hood, original cnd group buy $400
- Custom audi bixenon projector headlights (REAL HID'S), hella ballasts, hella FF50 driving lights, all in custom mx-3 housings. Custom headlight wiring harness: $400
- Custom Stainless mandrel bent 2.5inch exhaust from headers back. Gutted 2.5inch cat (pipe through it), Thermal Resonater, Racing Beat 2.5inch muffler, over axel, hangs on stock hangers. $400
- SS autochrome version 2 headers (flex pipe) Stainless steel, good shape. $200
- Momo steering wheel hub for mx-3 $45
- B&G springs, Tokico Struts, dust boots, top hats, camber bolts all new last year. $500
- Stock 15's 5 star mx-3 wheels, Hancook K102 tires 80% tread left. Rims are made by enkei, and are super light $300
- Stock Black Mx-3 hood $100
- Stock headlights, the set, pretty clear $30
- Pacesetter adjustable short shifter, SRD shifter bushings. $70
- CZT 67mm throttle body (KL36), beefed up throttle linkage spring, seealed throttle plate. $200
- Curved kneck ported KLZE intake manifold. Semi polished, knife edged inlets, Comes with all VRIS, red painted fuel rails, ZE injectors. 200
- Mike Seli reground intake cams. Grind: 0.353" lfit, 209deg @ 0.050" KLDE exhaust cams (better for nos/boost) $300
-Race Ported and polished KLZE heads. 3 angle valve job, resurfaced faces. only 6000km's $300
- 94 Mx-3 Disty, modified cap for external coil. Internal coil worked perfectly and is still in tact. Cap and rotor are almost new.
- Interprep valve springs /de retainers $150
- Megasquirt V2 with extras. Comes already wired into an mx-3 harness. Ready to plug in and go with a N/A KLZE tune, on my motor it was around 190-200whp, trapping 98-99mph $400
- MSD blaster 2 coil, Mallory Highfire 6AL Digital ignition box, coil bracket, MSD 8910 tach adaptor: $300
- MDX udp, silver. Fixed timing ring problem $40
-Toga HV oil pump, 6000km's $50
- KLZE phenos $50
-Mx-3 GS front bumper/lip, small crack on lip, black in colour $200
- NEW last year brake calipers all around, painted red, perfect condition only 6000km's. Slotted rotors new last year all 4, pads are still decent $350
- Goodridge Stainless braided brake lines all 4 $50
- Clutchmaster Stage 3 clutch, Mx-3 flywheel, lots of life in the clutch, was holding estimated 260whp perfectly fine. Chirps 3rd all the time $150
- Mx-3 GS tranny, no grinds $200
- SRD Billet aluminum crossmember (mx-3), scratched up from being dumped. Still stiff as hell, big upgrade over stock $100
- Rockford Fostage components (mids, tweaters, and crossovers) custom mounted in black mx-3 door skins (pw, pl) perfect condition. Song 222W amp and RCA's $150
- Brand new this year mx-3 Gas tank, maybe 1500km's on it. $100
Tons of parts im sure im forgetting. Complete mx-3 GS willing to part out. Lots of new parts. Heck i think the only thing not changed on this thing in the past 2-3 years is the control arm bushings. Endlinks, balljoints, trailing arms ect have all been changed recently.
Take the entire car as it sits for $5000 (minus the nitrous)
All parts are OBO, some i'd rather keep local. But willing to ship everything at the buyers expense.
- KLZE phenos $50
Last edited by Tyler17rose on September 17th, 2006, 2:23 pm, edited 1 time in total.
Mods:
- ZE, Mike seli 214 intake cams, Ported n polished heads, Interprep valve springs, DE retainers, rebuilt bottom end, toga main and rod bearings, toga hv oil pump, CZT 67mm tb, mbx udp, ported intake mani, SS headers, 2.5inch full exhaust, racingbeat muffler, highflow cat, megasquirt v2.
new toy, 86 TII rx7, JDM S5 motor/turbo, + alot of other goodies
some pics of the build last winter. And pics of the headlights/car:
![Image](http://img.photobucket.com/albums/v224/Mx3/rebuildapril028.jpg)
![Image](http://img.photobucket.com/albums/v224/Mx3/rebuildapril022.jpg)
![Image](http://img.photobucket.com/albums/v224/Mx3/rebuildapril011.jpg)
![Image](http://img.photobucket.com/albums/v224/Mx3/rebuildinprogress036.jpg)
![Image](http://img.photobucket.com/albums/v224/Mx3/rebuildinprogress034.jpg)
![Image](http://img.photobucket.com/albums/v224/Mx3/rebuildinprogress017.jpg)
Mods:
![Image](http://img.photobucket.com/albums/v224/Mx3/mx3010.jpg)
![Image](http://img.photobucket.com/albums/v224/Mx3/mx3004.jpg)
![Image](http://img.photobucket.com/albums/v224/Mx3/Manifoldpics007.jpg)
![Image](http://img.photobucket.com/albums/v224/Mx3/rebuildaprilenginein008.jpg)
![Image](http://img.photobucket.com/albums/v224/Mx3/rebuildapril046.jpg)
![Image](http://img.photobucket.com/albums/v224/Mx3/rebuildapril038.jpg)
![Image](http://img.photobucket.com/albums/v224/Mx3/rebuildapril036.jpg)
![Image](http://img.photobucket.com/albums/v224/Mx3/rebuildapril031.jpg)
Mods:
Once i get my digi camera back from a friend i can take a pic of anything you guys request.
+++ note heads were resurfaced and valves were ground after above mid porting photos. +++++++
Mods:
- mitmaks
pm sent
Never actually got it to the track after the megasquirt install and tune, but im sure i was running low low 14's because i was taking stock SRT-4's on the highway and from a dig, stage 2 SRT-4 was kneck andkneck, took down G35's like nothing.timpronk wrote:Out of curiousity, do you know what it ran all motor?
Id say 14.3 ish.
Mods:
- Dali
email me at unclesluggo@shaw.ca i want the brake lines and toga pump. thanks.
YOU sir will be my hero if you sell me the top transmission mount!!!! PLEASE
-hec
- mx3autozam
Throttle Body is mine
http://www.cardomain.com/ride/2385931/4
Car Name - Elsie (LC)
Car Type - 92 Black RS Stock 190k
Car Name - (yet to be decided)
Car Type - 93 (soon Black) GS KLZE 130k
