Rotary question!
Rotary question!
OK there is this 2004 RX-8 that I am looking at. Small water damager not even bad no rust anywhere they want $12k for this car. I don't know much about rotarys so I was going to see what you guys think. I started it up and it seemed kind of slugish a bit i left it idea for a bit and it cleared up. I started driving it trany clutch all felt tight in good shape. Car was rolling good all green lights everything running great. BUT if I try to get up on the car it would not want to go it would bog down get slugish just didnt want to pull like a normal engine. The engine light would start flashing. Then if you let of the gas and go back to normal driving it would go away drive normal and no engine light... What you guys think could be up with the car?
1994 Mazda MX-3 KL-ZE
if the body is in really nice condition then 12k isn't bad considering anything on a rotary can be replaced and repaired EASY and semi-cheap in most cases, do a few more test drives, see if the problem continues, you said when you got on it alittle it felt sluggish and boggy, your looking at not getting enough of something, either fuel or air would be the first things I check....
http://www.cardomain.com/ride/2385931/4
Car Name - Elsie (LC)
Car Type - 92 Black RS Stock 190k
Car Name - (yet to be decided)
Car Type - 93 (soon Black) GS KLZE 130k
- cjthor
If it has water damage I bet there is moisture in an electrical component. What type of water damage was disclosed to you?
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
not even up to the pedals i am thinking about just getting all the ECUs replaced or at least get them checked out. And then see what code is coming up. But they said that they put a full tank of gas in and they just drove around so it sounds like the car was driven for some time and it didn't bust down yet. so it must be something just miner.
- atlantamx3
- kiwi_MX3
- Location: Backpacking in Canada in vancouver 13march onwards
LooseChangeRacing wrote:if the body is in really nice condition then 12k isn't bad considering anything on a rotary can be replaced and repaired EASY and semi-cheap in most cases, do a few more test drives, see if the problem continues, you said when you got on it alittle it felt sluggish and boggy, your looking at not getting enough of something, either fuel or air would be the first things I check....
You have never owned a rota, from that quote, mazda rips
ya a new a--hole when you have to buy parts.
Legato,
Avoid this car, from this discription id say they have the engine
180 degrees out of phaze, it will run but be FLAT!
Or its got a cracked apex seal!
AVOID THIS CAR!
- cjthor
Pass...find one that wasnt water logged.Legato626 wrote:not even up to the pedals i am thinking about just getting all the ECUs replaced or at least get them checked out. And then see what code is coming up. But they said that they put a full tank of gas in and they just drove around so it sounds like the car was driven for some time and it didn't bust down yet. so it must be something just miner.
Jarid Perry
- Tunes67
I would avoid this car not only because of the water damage.. but cause of these kinds of articles popping up all over the net..
http://www.buzzle.com/editorials/8-28-2006-106828.asp
Supposedly there is a defect with the rotary engine design.. I dont know what the defect is.. and most of the articles that mention it dont get technical about it.. so maybe its nothing.. but.. its enough to make me think twice especially considering the cost of rotary engine parts.
Tunes67
Tunes67
- lowflyinmx3
like almost everyone else here i would avoid it, BUT, that article that tunes posted brings an idea to mind. the way tha article makes it sound is that the motor leaks oil and plugs up the cat. they said that the dealer will replace the motor and cat free of cost only if its found to be faulty. now a plugged cat could be a reason that the motor bogs down on you but i figure a clogged cat would be much worse than what you described. however if this motor is affected and found faulty, then you could buy it and take it to mazda and get a new motor and cat free of charge and you would have made out with pretty good car for 12k. that may be the problem but it may be electrical as well. it all depends on how much of a risk your willing to take.
Mazda.... What happens in the parking lot, stays in the parking lot
well the recall also has to due with not enough oil pressure to properly lubricate the apex seals-did u check the oil because rotaries inject it onto the apex seals to lubicate them so they dont dry up and CRACK like mentioned above so u may be able to get a new motor but maybe not so id check the oil ask how often they checked it and how much it burned and if they say it burned none run away as fast as u can cause they never took proper care of the car. y not wait a year and buy one not water damaged for the same price i think ud be buying a lemon. also check to c if its the 190 hp or 238 i think because the 190 is gutless. a way to tell by driving is to see where the rev limiter is if at 7500 then its the 190 hp and 2 less ports then the other version of the renesis as it has 2 ports that open at ---- rpm up to 9000 or 9500 but the first year some times has malfunctioning ports and they dont open buy one thats been maintained cared for and lved as the extra money up front will save u a ton in the long run
dohc b6, intake, exhaust, miata cams ready to go in
