high compression pistons??
Joey's mx
Post by Joey's mx »
Just wondering if there are high compression pistons available for the DOHC B6??
Miata maybe??
cjthor
Re: high compression pistons??
Post by cjthor »
Joey's mx wrote:Just wondering if there are high compression pistons available for the DOHC B6??
Miata maybe??
There are...weisco makes em. http://www.flyingmiata.com
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
MechaManZero
Post by MechaManZero »
Ahhhhh what are you doing you have a turbo mx-3 buddy. High compression plus turbo equals god knows what lol.
Çlark
95 Mazda MX3 4 Banger
Currently: H&R Lowering springs, BPT from a GTR, 18.5x6x3.5 same side inlet and outlet intercooler, Centerforce Dual Friction clutch
For BPT Frorums - http://www.aokforums.com/mazdaengines/
WingleBeast
Post by WingleBeast »
yeha higher horsepower, high octane gasoline, and kigher risk of ping.
run less psi and it should be ok
95 rs
Post by 95 rs »
hes not turbo'd anymore... hes selling all his stuff...
95 rs with custom short ram air, b&m short throw shifter, probe 2.0L header with 2 1/4" exhaust all the way back, catco high flow cat, apc high flow muffler with 4.5" tip, accel 8 mm wires, blaze red, cf altezzas, gun metal 17" mr7s, slotted cross drilled rotors on the way with hawk hps pads, red and white interior, other then that its stock.
MechaManZero
damn joey why lol
Çlark
Limegreen mx-3
Post by Limegreen mx-3 »
Miata maybe??
a lot of the 1.6 miata stuff is interchageable with the 1.6 b6 in the 94+ MX-3
cams, cam gears, rods, pistons, UDP, head gasket, alm. flywheel&clutch, etc that i haven't written.
http://www.todaracing.com
Boris
Post by Boris »
Why didn't the turbo work out?
Joey's mx
Post by Joey's mx »
i dont have the time to play around with the turbo stuff!!
Now are these pistons from fliyinmiata drict drop in?? 2mm overbore..does the block have to be sleeved or do the pistons just install without anything else??
Rayted_m
Post by Rayted_m »
yea best bet is to go to flying miata but they are very expensice. also check corksport.com
**~Rayted-M~**
Team **~N.M.E~**
**~CROWN LEGION~** Caloboration
MX-3 Civic head light conversion
http://www.cardomain.com/ride/688645
Rayted_m
Post by Rayted_m »
i just found a real good place to find pistons. the best price ive found. it comes from racingmazda.com check that out.
**~Rayted-M~**
Team **~N.M.E~**
projectmx
Post by projectmx »
you can also order direct from wiseco that is what i did
and there is nothing wrong with high compression and turbo.. pros do it
i'm doing 10.5:1 with turbo
ProjectMx
My BP and AWD build thread
Cardomain
93 Mx-3 GS with bp and GTR AWD system
93 Escort GT daily driving
Post by Josh »
exactly, the higher the comp the better and more precise the tunning has to be. damb Joey just drop in a BP, dont waist the time on a B6. you could drop in BP pistons, it will have to bored and should be resleved, but would be kinda sweet. N/A vs N/A the BP has so much more potential. but then again you have the cams too.
The B6 block is already bored as far as its supposed to be as it origionally started its life as a 1.3L and was bored to a 1.5 then later the 1.6. so with that said 1mm overbore is suppoed to be the max. BUT N/A 2mm would probably be fine, unless you plan on running NOS or a power adder. you could see if some one can make you a one off stroker kit, and you could probably get the displacement up u bit. i would still you your AFC to tune ui up though.
you should run ITB's (indepentant throttel bodies) how bad a-- would that be. alot of guys are using them off of like GSXR's and Ninja's, but you could do it if you had one plenium on there. that would be bad a--.
Cy
Post by Cy »
While ITB's are the best... even with a 2-piece plenum..
What i've got plans to do is what you can already get for honda's...
It's a spacer plate that goes between the IntakeMani and the head...You put long necked injectors in this plate and it puts them literally almost into each port on the head..Then make 4 Straight runners with rolled back ends and box it in with a TB mounting plate on 1 end..
It is the same as ITB in it's tunability you would just want a tuner that can map individual injectors.. a UEGO guage on each cylinder is also recommended.. (with ITB's too)..
BuGS
Post by BuGS »
Cy wrote:While ITB's are the best... even with a 2-piece plenum..
Tunability is the same, but those setups still are crap for responce. ITBS are the fast responce setup and so far I havn't seen a faster responce setup...
